Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 02-18-2002
Rdub Rdub is offline
Newbie
Rdub is on a distinguished road
Can a 424mkIII do this?
I have a PC with a normal single input soundcard. My band has done minimal recording using N-track & my PC, which is a pain because of all the overdubbing we have to do.
My guitarist was thinking about getting a 424mkIII so we could get more tracks down at once & because of the quality of this 4 track unit. I would really like to get a multi input soundcard & a mixer, and do all the recording on my PC. Just don't have the bucks to do that though.
My question is this: If my guitarist got the 424 & we recorded four tracks on it....could we then move each of those tracks "individually" over to my PC with N-track??? Then use N-track for the mixdown, etc.
The result I want is to have the four(or more) separate tracks in N-track rather than a two track stereo mix from the 424.
Is this possible? Need more Info? I was trying to keep it short & to the point.
Thanks - Would appreciate any help
Old 02-18-2002
Atwork Atwork is offline
Dedicated Member
Atwork is on a distinguished road
By individually do you mean one by one? You could do that, but I would expect editing the tracks so they synced up to be a pain.
As I think you know you can't transfer tracks simultaneously and get them on separate tracks in n-Track, without a soundcard with multiple inputs and software which recognizes each input as a separate input.
Old 02-18-2002
Newbie
Atwork
Is my "individually" the same as your "one by one"??-- Probably
To clarify: once all four tracks were recorded to the 424, then I'd be making four passes of playing each track on the 424 & recording to N-track. This would eliminate us having to play the song 4 times to get the four tracks to N-track (which is basically what we're doing now).
If the 424 will do this, then it answers my question. If after doing this, and syncing the tracks becomes a problem....well, then that's a whole new issue I'd have to deal with.
Ultimately, I want to use N-track & work with everything on the PC. The 424 was my "econo" way of trying to accomplish this, but I certainly don't want to deal with a lot of frustration in syncing tracks doing it this way.
I really just need to find $1100 for a mixer & multi input soundcard (sigh)
Old 02-19-2002
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
Originally posted by Rdub
Atwork
1) Is my "individually" the same as your "one by one"??-- Probably
2) If the 424 will do this, then it answers my question. If after doing this, and syncing the tracks becomes a problem....well, then that's a whole new issue I'd have to deal with.
3) I really just need to find $1100 for a mixer & multi input soundcard (sigh)
1) Yes, you could transfer the 424 four seperate tracks over to the computer.
2) You will have to lay a "sync tone" across the beginning of all your tracks (while they are in the 424).
3) It would be easier and cheaper for you to purchase a soundcard with 4 INPUTS. For example, the DELTA 44. http://www.midiman.net
Once, you save up enough money you could pick up a board. Until then, you could do your mixing in the computer.
The soundcard will be cheaper than the 424MKII.
Peace...
spin
Old 02-19-2002
Dedicated Member
It looks like a multi input soundcard is the only answer for recording in the way you describe. You'd have to make sure though that the PC can read each input as a separate input. I have a four input soundcard, but the PC can only read them as two matched pairs. So even though I have 4 inputs I can only record two separate tracks simultaneously in n-Track.
You might not need $1100 to do what you want to do. The Delta 44 as Spinsterwun said costs less than a 424. I don't know how its inputs are read, though. You could get a cheap mixer for under $100, though saving up for a better one would probably be better. $350-$400 tops, potentially.
Plenty of clued up people here to ask, don't forget. You should be able to sort something out.
Old 02-19-2002
Newbie
Atwork & Spinsterwun - Thanks for your help!
I'll probably pass on using the 424 in the way I've described, and ultimately get a better soundcard & mixer.
In a soundcard, I would need preamps too, which is why I mention a mixer. I also see using the mixer for "live" use as well. So it looks like the soundcard/mixer combo better meets my needs for everything.
thanks again
