Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 02-16-2002
notCardio notCardio is offline
I walk the line
notCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond repute
Question Newbie preamp question for Bruce et al
Help me understand something, please!
This is a hypothetical situation, so I'm not looking for responses involving specific gear. It's the idea, or theory if you will, that I want to get straight.
Let's assume, for the sake of this question, that the following is true:
A Behringer mixer's preamps suck. (that's why I mentioned you, Blue Bear)
A Midiman Audio Buddy's preamps rock. (or any other relatively inexpensive preamp of your choice)
If you take the output of the Midiman into a line in of the Behringer (thereby bypassing the sucky preamp, right?), would you get the benefit of the nicer preamp, or not?
I would think so, but I'm not sure. Or is it dependant on the quality of the mixer, regardless of how it's preamps sound?
I hope this makes sense.
Old 02-16-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Yes, you'll bypass the Behringer pre... but then the signal will get f*cked by the crappy Behringer EQ circuit (unless it's defeatable)...
Best to take the preamp output directly to multitrack (or soundcard input), as the case may be!
Bruce
Old 02-16-2002
I walk the line
Even with EQ flat?
So, even with the EQ flat, your still going through the EQ circuitry, so if a mixer has crummy EQ, unless there's a physical bypass, your still hosed? What if you go through a line input that only has a level control, and no EQ?
Old 02-16-2002
If there is no "EQ Defeat" switch, then you are always passing thru the EQ circuitry, even if the control are set to their nominal position.
One of the most basic recording rules is for minimal signal path. If something doesn't need to be in the chain, don't route the signal thru it. If you're using a pre, there's no reason for the signal to travel thru a mixer at all, unless you're blending it with other tracks.
Bruce
Old 02-16-2002
LongWaveStudio LongWaveStudio is offline
1K Silver Member
LongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond repute
hmm, well fair enough, but whats not good to one person may be good to another. this is not to say that behringer pre's are good, but to some people, it may be all they have and it may sound great to them. on another level, they may be able to make it sound great.
________________
Long Wave Studio
07980 265366
Old 02-16-2002
Actually, Romesh - re-read the thread, that's not really the point at all!
He's not talking about specific gear, the Behringer's only an example....
Bruce
Old 02-16-2002
I walk the line
Thumbs up Correct again, BB!
The Behringer was just an example. It could have been a Rolls, or an M-Audio, or Crate, or a Phonic or a Ghost. I just wanted to make sure I understood the principle, which I now do, thanks to you.
And I understand about the shortest path, I was just thinking if I had to "pre-mix" something to record in stereo, Like if I were recording several guys sitting around playing acoustics & singing live, and there were more mics used than I had mic pre's on a mixer.
I know. I should have better things to do than sit around and think of sh*t like this, but it's just how my mind works.
Thanks as always.
Old 02-17-2002
1K Silver Member
sorry bruce, i thought you were knocking his mixer
________________
Long Wave Studio
07980 265366
Old 02-17-2002
Henrik's Avatar
Henrik Henrik is offline
Dedicated Member
Henrik is on a distinguished road
Bruce?
5-2.
Old 02-17-2002
Huh?
Sorry Henri, you lost me there!
Old 02-17-2002
Track Rat's Avatar
Total Gear Slut
5-2.
I think it means you're winning. You're three ahead.
Mike
  #12
Old 02-17-2002
Red face
Doh!
  #13
Old 02-17-2002
Henrik's Avatar
Dedicated Member
OH, sorry. I just assumed that being Canadian, you were interested in ice hockey. Sweden beat Canada with 5-2 the other day.
Just wanted to rub it in.
Cheers
/Henrik
  #14
Old 02-17-2002
Unhappy
Oh! Actually... I did see that game!
Double-DOH!!!!
Bruce
  #15
Old 02-17-2002
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
speaking of mic-pre's, i just got the m-audio audiosport duo, and thus far i really like the mic-pre's. i think it may actually be an upgrade from my mackie 1604vlz pro's mic-pre, but i'll know for sure when i listen to the tracks a few weeks from now when the NEW has worn off and stops clouding my judgement.
