Old 02-14-2002
samich17's Avatar
samich17 samich17 is offline
Dedicated Member
samich17 is on a distinguished road
Having Studio Problems
I should start this problem out by explaining my old set-up..and that I am posting this here, because it seems like the right place.
I plug my instruments and microphones into my Fostex XR-5 4 track.. i go (stereo out) via A/V-1/8" cables into the Soundblaster Live and out of the Soundblaster via A/V cables into my tape deck and listen to everything with my stereo speakers..I use Cool Edit 2000 to record and mix. Everything works fine.
Now I just got and installed my Echo Mia card, keeping the Sounblaster in with it. Everything setup fine. Now I'm not sure how I alter my set-up. I'm bringing this problem here, because you guys are more helpful than the manual.
This is what I've tried so far and still can't get a signal with Cool Edit 2000, though I am getting a weak signal in the Mia console.
I unplugged the cable from the Soundblaster that was coming from the 4 track, put on a 1/4" adapter, and plugged that into one of the inputs on Mia. I also changed the Recording Device in Cool Edit 2000 from Soundblaster to Mia. That's all I've done so far and am not getting a signal.
Please help me fix this.
Also, am I suppose to unplug the cable connecting the tape deck and Soundblaster and connect the tape deck to Mia? The Mia has 2 outputs, though I'm not sure if I have to use these or if I should just keep the Soundblaster plugged into the tape deck. Will the quality of sound differ depending on what card it is coming out of?
I know these questions might sound dumb to some of you, but I'm asking you guys because the manual is confusing. I did check all the passed Mia posts and found nothing to help me with these problems. thanks a lot
