Old 02-12-2002
bubinski's Avatar
bubinski bubinski is offline
Senior Member
bubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond reputebubinski has a reputation beyond repute
Pinch Roller Cleaner ?
Anybody know what the basic fluid of pinch roller cleaner is ?
The guy with the radio shack in the back of the corner store here in nowhere montana don't even know what a pinnch roller is. He just sells dish's and cell phones and scanners and did'nt even have a catalog.
Hope to find out so I can go to the hardware store and buy a gallon.
bubinski.
Old 02-12-2002
Krakit's Avatar
Krakit Krakit is offline
Rzzzzz!
Krakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond repute
I used to use isopropanol back in the day.
However, when I was repairing VCR's (had my own business in the 80's till the things got to cheap to bother repairing), I found a solution called "Rubber Rejuvinator" that worked brilliantly.
Look on the web for it.
Carl
"Just a pinch between the capstan and roller will get you through the day"
“The modern conservative is engaged in one of man's oldest exercises in moral philosophy;
that is, the search for a superior moral justification for selfishness.”
-John Kenneth Galbraith
Old 02-13-2002
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
DON'T USE ISOPROPYL ALCOHOL ON PINCH ROLLERS!!!!!!!!
It dries out the rubber very quickly cause it to crack... you should use the rubber cleaner formulated for pinch rollers available in any electronic component supply store (which Radio Shack is not!)
Bruce
Old 02-13-2002
harley96's Avatar
harley96 harley96 is offline
where did my summer go?
harley96 is on a distinguished road
I use 99% Isopropyl alcohol.Anything under 90% is no good as Blue Bear noted that it will dry out the rubber and crack.I am pretty sure anything under 90% contains 10% or more water so that's definately not good.I assume rubber cleaner is a good idea even if 99% Isopropyl will work.......
Old 02-13-2002
Krakit's Avatar
Rzzzzz!
Actually Harley, Bear is right. I was a newbie when I was using Isoprop, and there was no one around to tell me that it was bad for rollers.
I wasn't using it on pro equipment anyway. I started repairing VCR's before I started buying porta studios and I only used "Rubber Rejuvinator" on my gear or in the studios that I eventually worked at.
This thread had me investigate my "old ways" by way of google.
No one reccomends Iso for roller cleaning. All stating the same reasons that Bear has for not doing so.
Interesting enough, I've seen more than one site reccomend "Fantastik" or "409" cleaner. However, I'm a bit incredulous that these would work too well. Who knows?
So, you learn something new everyday.
Carl
