Why is my sound so "tinny"?
I am miking steel string acoustic and I am getting a very tinny sound with a sometimes explosive poppy bottom end. I am miking with an AKG C3000B and an Oktava MC012 with the cardioid capsule. The AKG is about 6-8 inches away and 3-4 inches above the whole. I have used the Oktava both above and below pointing to the middle of the neck anywhere from 10 inches away to 2 feet.
Running through a dbx 31 band EQ post trim through the inserts on a Mackie VLZ 1202. I set the EQ and later checked the c3000b frequency response only to find that I ended up "flattening" the response of the mic! Is the AKG c3000b just that bright? I have only had the mic for a month. Recording on a Roland VS-880EX. The guitar is a spruce solid top, maple sides and back by Hohner. It doesn't sound terrible, but it is lacking that big in-your-face feel. How do I get that sound? -c |
You need a decent pre.
Best check that you haven't got phase problems.
two mics near eachother can often cause them and takee a lot of bottom of the sound away.
www.protoolsforum.com The board for all Pro Tools (LE) users!! Finally back online. |
You can get great results with the Mackie pre's so I doubt that's your problem. I've also had good luck with both the mic's you're useing. I'd stay away from the 31 band EQ like the plague. And yes, the C-3000 is that bright. The high end is "hyped" but it's still a very useable mic. Can you post and example of what you're talking about?
Mike |
i reckon it's phasing too. the c3000 should give you a really nice guitar sound. try not using the oktava. see how that helps.
________________ Long Wave Studio 07980 265366 |
