Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 02-09-2002
amt7565 amt7565 is offline
Force of Nature
amt7565 is on a distinguished road
Guitar to PC. what sound card?
hello folks!
I am faily new to MIDI. Please answer the following questions. It will greatly benefit me. Thank you!
1. I only use one Guitar to plug into the "line in" of my 'Soundblaster digital value" sound card. Is this soundcard good enough? Or do I need an external sound card? I am using SONAR.
2. Is a mixer necessary to use only 1 guitar input and all the rest of the tracks for internal MIDI? If not, is a mixer recommeneded if I am using an external synth module?
Thanks again!
Old 02-09-2002
Slackmaster2K's Avatar
Slackmaster2K Slackmaster2K is offline
Gone
Slackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond reputeSlackmaster2K has a reputation beyond repute
Whoa hang on there. Do you have one of those MIDI guitars?
It sounds like you're using the term MIDI wrong. MIDI has no sound, it's just messages passing between devices.
Most soundcards have MIDI input ports, and you can, for instance, hook a MIDI keyboard up to your soundcard and use it to play soundfonts on your Soundblaster Live! Value. NO SOUND passes between the two though, MIDI messages are sent to the soundcard instructing it to, for instance, play a particular sound.
You want to somehow record your guitar. In order to record your guitar, you either need to run some sort of guitar preamp device (like a POD or JStation) into the line in port of your soundcard, or use a microphone and mic your amp.
A dynamic microphone like the Shure SM57 is a good starting point for mic'ing an amplifier, and you can technically plug it in to the mic in port on your soundblaster. It is recommended, however, that you eventually get a decent microphone preamp...but it depends on your needs, and we don't know your needs yet. A mixer in this case would only be useful because they typically have built in microphone preamps. See a microphone outputs a very low level signal, so you need what is called a "preamplifier" to amplify the low level signal to line level. This process is, as odd as it may seem, VERY important to your sound quality. The MIC IN port on your soundcard has a cheap little microphone preamp built in.
External soundcards and internal soundcards are for all intents and purposes the same exact thing. A soundcard is basically just an A/D/A converter, in that it converts analog signals coming in to 1's and 0's that the computer can understand, and also converts those little 1's and 0's back into analog sound that you can actually hear.
So anyway, anything that has a LINE level output can be plugged into the LINE IN port on your soundcard and you can record it. You can hook either a computer microphone or a dynamic microphone into the MIC IN port on your soundcard. MIDI devices can be hooked up to the MIDI/joystick port on your soundcard. Once you get a handle on these simple concepts, you should be able to at least get started.
Good luck to ya!
Slackmaster 2000
Slackmaster 2000
Old 02-09-2002
Force of Nature
Slack,
I think my post was misleading. nevertheless your post was useful. I am sing my guitar through an amp into the sound card. I am also using MIDI softsynths using SONAR. So I am using one audio and many MIDI tracks.
Thanks!
Old 02-10-2002
Gone
Ok, I'm not sure what you're asking still...but...
1. Yes that soundcard is good enough, at least to start with.
2. No you don't need a mixer.
Slackmaster 2000
Slackmaster 2000
Old 02-10-2002
Force of Nature
Slack Thanks!
I am not fully happy with the digital values SB soundcard. I like some better pro audio quality. I need something which will provide me quality for not only my guitar but also for converting from MIDI to Audio-mixdown etc. Do you have any recommendations?
Can you also recommend a good MIDI sound module so I can get more realistic sounds out of MIDI? I am currently using SONAR DXi soft synths.
Thanks again!
AMT-
