Old 02-08-2002
notCardio notCardio is offline
I walk the line
notCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond repute
Question Soundproofing plumbing
If this has been done to death, someone please be kind enough to point me in the right direction.
My playspace (and hopefully one day studio-to-be) is in my basement, which also has a sump pump. What is the best way to eliminate as much noise a possible from the drain pipe (about 4" PVC)? The sound of the water rushing through is REALLY loud. It's located inside a wall separating the basement and the stairway leading down to it. Fortunately, the side of the wall facing the inside of the basement is completely open, so I can do pretty much whatever I need to without demolition. If I use standard fiberglass insulation, and the insulation touches both the pipe and the wall, will that transmit sound? Or do I want to cram as much into it as I can? I can deal with the layering of the drywall, I just dont know what to do about the insulation, and I don't want to find out I was wrong AFTER the drywalling.
Thanks
Old 02-08-2002
VOXVENDOR's Avatar
VOXVENDOR VOXVENDOR is offline
Shhhhhh, it's a secret.
VOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond reputeVOXVENDOR has a reputation beyond repute
I can't really offer any advice... I know that masking plumbing noise is one of the hardest aspects of sound proofing..
If you can have the pipes moved by a qualified plumber for a few hundred bucks, you might even be better off that way....
Sorry, I can't be of more help..
Joe
