Old 02-06-2002
1 1 Meta 2 2 2's Avatar
1 1 Meta 2 2 2 1 1 Meta 2 2 2 is offline
Junior Member
1 1 Meta 2 2 2 is on a distinguished road
Thumbs down Pod -> 1604 Vpro Aux
I can list connections yada yada .. why when it is apparent to me that.. it simply doesn't work! hahahaha
Anyone ever had success using POD with mackie aux send/ret.
Thanks
Jeff
meta
Old 02-06-2002
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
im thinking the aux send return is gonna put a line level signal thru it, but im really confused at this point....i dont that this is the optimal situation for a amp modeling device......id go straight into the recorder from the POD.....
Old 02-06-2002
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
what isnt working? No signal, low signal, what?
Old 02-13-2002
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
so are you trying to be slick and use the POD as an fx box?
are you doing this so that you can use the POD on more than one track at a time?
if so, make sure that the aux send on the channel is up, and the aux input and output levels for the aux itself are turned up.
if not, then why aren't you using the POD as an insert? get a Y cable and put the TRS side of the cable into the mackie for the desired channel, and plug the In/Out 1/4 ends of the Y cable into the approprite out/in 1/4 female recepticles on the POD.
Old 02-13-2002
Meshuggah's Avatar
Meshuggah Meshuggah is offline
Commie Bastard
Meshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to allMeshuggah is a name known to all
I used a POD as an effect on an accordion once... signal went from Direct out on the channel -> POD -> Aux return Right -> Main. So the original signal was panned hard left, and the PODed signal was panned hard right. verrry cool sound!!
I want [img]-code in the sigs. now!!!
Old 02-13-2002
Gidge's Avatar
Lapdance Test Dummy
Cool
i love my J-Station because i can go in with a siganl and come out with a clean stereo sound AND a stereo channel with effects simultaneously....lots fo options at mixdown.....
Old 02-15-2002
Phildo Phildo is offline
I heart guitars!
Phildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond repute
I've not done it with a Mackie, but I run my bass Pod off an aux send on my VS1680 all the time and I've NEVER had a problem...
Handy Pod hint: If you've recorded a live (mic'd) bass, then record a DI track at the same time, and take a feed from the DI and patch it into a bass Pod set on the "Subdub" preset. Whack the compression right up, mix to taste and wa-hey! Huge, deep, CONTROLLABLE bass which doesn't compromise the player's original sound. I'm aware that this should cause all manner of phase and comb-filtering problems due to the latency of the Pod, but in all honesty I've never noticed any.
"I killed the President of Paraguay with a fork..."
www.myspace.com/germanfilmstars
www.myspace.com/weirdoiom
www.myspace.com/stoliday
Old 02-15-2002
KaosDG KaosDG is offline
Newbie
KaosDG is on a distinguished road
I'm using my POD 2.0 in the effects loop of a mackie 1202VLZ Pro, works just fine...
A few things to check would be to make sure the EFX 1 Master is at Unity Gain,
Switch set to "post" (So it follows the gain controls of the channel you are using on the Mixer)
Also make sure that channel's efx send is turned up, at least to U So you can hear it.
EFX to monitor should be off for the time being
Are you connecting in stereo?
If not, Make sure you are using both the Left output of the POD into the Left AUX Ret. on the mackie.
Also make sure the levels on the POD itself are up, since optimally the Output Level on the POD is supposed to be Line Level when set to max.
