Old 02-02-2002
snunn snunn is offline
Newbie
snunn is on a distinguished road
DV to VHS
I'm trying to record video from a DV tape onto a VHS tape in a VCR. I've got the video and two audio cables going from the DV camera to the "in" jacks on the VCR, I start play on the DV camera and record on th VCR but nothing happens. Should all VCRs be able to record from a DV camera?
Old 02-02-2002
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
That should work just fine. Once it comes out those componenet video cables it's a standard video signal. My own VCR has a couple of inputs that can be selected -- front, back -- and I need to be sure to select the one I plug into. Maybe that's your issue?
Old 02-03-2002
Fangar's Avatar
Fangar Fangar is offline
Force of Nature
Fangar will become famous soon enough
AlChuck said it right. I would better a bugger, ( I mean Burger) that you have the wrong input selected on the VCR. Also check to see that the camera is in Play or VCR mode.
Fangar
Old 02-03-2002
Newbie
I found the VCR instructions and it directed me to key in a sequence of numbers via the remote to put it in record mode. I was using the right inputs but they were not active. I've never heard of having to take that step, but it did work. Thanks for the help.
Old 02-03-2002
Fangar's Avatar
Force of Nature
Glad that it worked out. Cheers
Fangar
