Go Back   Home Recording > User Forums by Brand > Sony Tools / Sonic Foundry
Reply    Audiofanzine Sony Sony News Sony Medias Sony Tests Sony Articles Sony User Reviews Sony Classifieds Ads
Old 01-25-2002
maltobello maltobello is offline
Newbie
maltobello is on a distinguished road
getting acid to recognize new plugins.
does anyone know how to get acid to recognize new plugins? i tried copying the .dll's to my sonic foundry plugins folder, but acid (music 2.0) won't recognize them. any ideas?
thanks
Old 01-25-2002
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Eeek, don't go copying those dlls around....
Plug-ins get registered in the registry. Then the typical apps read the list out of the Windows registry. When a new plug-in gets installed, they should appear in the list.
Did you by any chance just copy the DLLs off of another system and expect them to work by putting them somewhere?
I suppose it's possible some plug-ins might not install themselves properly... also that the check-the-registry process might not be perfect...
I know that someone had posted a way to make sure something appears in Cakewalk's list. Perhaps the same steps apply here except for the names of any Cakewalk-specific registry keys, if any...
Old 01-25-2002
Newbie
i did run the install program...but that didn't seem to be enough for acid. good thoughts though...i tried running regsvr32 on the dll, to make sure windows knows it's there. this is my first time installing directx plugins, and i'm not sure if there's anything acid needs to become aware of them.
Old 01-25-2002
Newbie
this got me looking around on the acid planet board...turns out my version of acid (music 2.0) doesn't support plug-ins, just the effects that sonic foundry supplies...i guess that's why acid pro costs so much.
thanks for your help
Old 01-30-2002
P Hallin P Hallin is offline
Senior Member
P Hallin is on a distinguished road
I have acid 2.0 and have no problem with my plugins. I find them for example at www.directxfiles.com or something install them and presto! their in the list.
Do you have soundforge also? I do and that is where I use my plugs mostly, I only use acid to cut and paste and mixdown.
I was thinking mayby it works to have both for the plugs to install properly?
Old 01-30-2002
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
Originally posted by maltobello
....turns out my version of acid (music 2.0) doesn't support plug-ins ....
Yeap, you're going to have upgrade to 2.0, or preferrably, 3.0.
Peace...
spin
Old 01-30-2002
AlChuck's Avatar
P Hallin, SPINSTERWUN,
ACID Pro 2.0 does, but not ACID Music 2.0, the cheaper version...
I believe the same situation exists with version 3... that is, ACID Pro 3.0 will support third-party DirectX plugs but ACID Music 3.0 will not.
Old 02-02-2002
gec gec is offline
Force of Nature
gec is on a distinguished road
Acid is a pain in isazzzzzzzzz when it comes to plugins 2.0. 3.0 or pro it don't matter I've been battlin plugin problems since thier first release. But after losing all your hair you'll get it to work
Old 02-12-2002
tonyA's Avatar
tonyA tonyA is offline
Senior Member
tonyA is on a distinguished road
If you really need that sound that the plug in provides that Acid won't recognize, check if Sound Forge recognizes it and add it to the sound wave (make sure you make a back up of the original wave file because the change is irreversible). That is one workaround.
Another is to uninstall your Acid and reinstall them again after your plug ins are installed and running. Acid normally checks the disks for any plug ins you have available before completing its install. My Acid 2.0 and 3.0 have no problems recognizing plug-ins even those by third party manufacturers.
Good Luck!
Tony A.
