Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 01-22-2002
wes480's Avatar
wes480 wes480 is offline
1K Silver Member
wes480 has a little shameless behaviour in the past
How do I record my Synth? (S80)
I have tried recording before to my DAW by just using the L/R stereo outputs with 1/4" cables into my mixer...and...that sounds fine...i guess. What I am wondering is if there is a better way?
More if I had a lot of sequencing setup. Like, a nice midi arrangement, that I was ready to turn into audio so that i could mix it and eq it etc. Do I just get it setup to play back through the Yamaha S80, and then record the 1/4" stereo outs?
Or is there a cleaner way to get MIDI to audio? Or..is everyone just using virtual instruments now...and just using the synth as a keyboard to input the notes? Just curious on whats the best way to do things these days. thanks.
Old 01-22-2002
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
I suspect you are doing what everyone else is doing. Yes virtual instruments are becoming more popular and more extensive but I'd keep at it.
cheers
John
Old 01-24-2002
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
The best way to do it is to play your sequence and record the individual instrument sounds to their own tracks. You will need to have your sequencer synced to the DAW. Sonar and Logic will handle the midi and the audio.
This way you can use compression and other software effects on the individual sounds and be able to have much greater control over the final mix. Another advantage is you dont have to worry about polyphony since the synth will only be playing one part at a time.
