Ntrack, with a multichannel soundcard.
I have a question regarding the use of a multichannel card, like a delta 44 or 66 with ntrack. how would you set it up to record 4 seperate tracks, for the four mono inputs.
try as I might, i cannot figure this out. any help would be appreciated |
In Preferences / Wave Devices you'll see a list of al the drivers for inputs and outputs availible in your machine.
Select all the inputs for your card (in whatever driver flavor works best for you) by Control + Clicking on each one. They might be something like "ASIO Delta 44 1&2" and "ASIO Delta 44 3&4" When you click OK, your input meters should sprout 4 tracks set up in 2 stereo pair. Going into the setting for each pair change them to record 2 mono tracks instead of 1 stereo track. I don't have the program in front of me, but I think that's how it works. Close enough, anyway. Good luck, Chris |
Yep... everything is set in Preferences (Control-P).
Also be sure anytime you upgrade to a new build that you go back into the Preferences and reset them to your setup! Preferences will always change to the defaults any time you upgrade the program. |
