Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 01-20-2002
Mastermindzz Mastermindzz is offline
Senior Member
Mastermindzz is on a distinguished road
Looping drums in N track
I've exported drum patterns from Fruity Loops in N track and they are about 2 sec long, I can't get these things to loop in N track continously,I've copied pasted and it makes a new track, I want it all on one track, what am I doing wrong???
Old 01-20-2002
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Why are you only exporting 2 second loops? It's >much< easier in any sequencer (not just n-track) to build up entire phrases of 4 or 8 or 16 measures - or even the entire song- in Fruity and then export them as a .wav you can bring into the sequencer.
Don't make things harder for yourself.
That said, when I do a short phrase in FruityLoops I bring it into n-track, turn on the grid, highlight it and hit copy (control-c). Then just hit shift-control-v (paste at end of loop) until it fills up as much of the track as needed.
Old 01-21-2002
Tom Hicks's Avatar
Tom Hicks Tom Hicks is offline
1K Silver Member
Tom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant future
Be careful about cutting off cymbal tails when looping.If you have a cymbal ringing at the loop point,there will be an audible noise as it is cut off.On the other hand,if you choose the "wrap" function when exporting from fruity,now the tail will be at the beginninng of the track!My solution is to clone the pattern instead of looping it,so the cymbals ring and fade naturally.Timing has to be done by hand using offset,bet the final result just sounds better.I agree with Slack.2 seconds is way too short for a pattern,too obvious to the listener its only a pattern.My patterns average about a minute.Try to fool 'em a little bit.
Tom
Old 01-21-2002
Senior Member
The problem is I can't make the wave any longer than two sec, how do i change the measures, I made the pattern but the pattern is only two sec, that's my problem, I would like to make about a minute then loop it on N Track but that's my problem, I don't know how.
Old 01-21-2002
2.5K Gold Member
Ohhhh, you don't know how to sequence in Fruity??? ReadTheManual. All you have to do is open the sequencer window and in the pattern click the little button (it's tiny) that says "Song" instead of "Pattern"!
You can build quite complex sequences in Fruity and it's well worth learning how to use it... it's a great tool. Some people use Fruity as their main sequencer!
You should also be on the lookout for "Computer Music" magazine ( www.computermusic.co.uk ) in the bookstore. They've been running tutorials on Fruity and each issue comes with a CD that not only has great software - some demo, some full versions - but also tons of free samples that can be used in Fruity and N-Track or any other program. Definitely worth the price!
