Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 01-15-2002
Forenzikks Forenzikks is offline
Newbie
Forenzikks is on a distinguished road
should I compress my beat and vocals seperatley then mix them?
Ok I ve gotten my beats that I make which are rap beats to sound ok by using ozone......so my question is is should I get my beat sounding right by using compression and other tools in ozone first and then compress my vocals and add reverb etc. and get them to sound right and then mix em into one track and just touch up that one final track.....or should I just mix everything vocals included into one track and then all at once apply compression and everything....reason is is becuz I cant get my vocs to sound good so I have to do a lot of editing to them seperatly so would it be better to just get my beat good and then my vocs good .....mix em......and then go back and touch it up with a little overall eq and compression and then call it good....thanks for any help
Old 01-15-2002
Whoopysnorp's Avatar
Whoopysnorp Whoopysnorp is offline
Huh huh..."member"
Whoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond repute
I have a feeling it'd sound weird if you compressed your beat seperately from your vocal. Get you vocal recorded, edit it, and then master the whole file.
Old 01-15-2002
struberg's Avatar
struberg struberg is offline
charhizma mb
struberg is on a distinguished road
You also can compress seperately depending on the track (for further explanations ask Ed (Massa sonusman) or Harvey Gerst)
Bur first of all:
1st reverb
2nd compress
thats what i heard somewhere: reverb after compressing sounds somehow strang in most cases
Old 01-15-2002
LongWaveStudio LongWaveStudio is offline
1K Silver Member
LongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond repute
think about why you're compressing before you do it. it doesn't always make things sound good. infact, it can ruin some beats / vocals if not done properly.
________________
Long Wave Studio
07980 265366
Old 01-15-2002
Cwadroon Cwadroon is offline
Senior Member
Cwadroon is on a distinguished road
Vocal Problems
Anyone know of some good plugins or effects, or eq settings for vocals? I just can't get them to sound "full" enough.
Thanks for any reply.
Old 01-16-2002
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
i pretty much disagree with everything said so far:
If your tracks need it, then they should be compressed (hopefully non-destructively) individually.
If you are using midi (drum machines, sound canvas, samplers etc..) to create your music, you can compress the velocity of the notes played in midi such that you get the dynamic range that you are looking for using midi before recording the midi tracks to analog. Then (if you need it at all) you won't have to compress as much.
Think about this:
If you mix the whole of the sound together, then the offending instrument is causing all the other instrument's levels to be reduced as well, so you haven't accomplished the goal of mixing which is to get each instrument to stay in its proper place in the song.
If you record well, and your musicians are good at their craft, you won't need to compress as much... on the guitar I can pull that off, but on the bass I'm all over the place so I have to compress the snot out of it. What I don't want is the bass compression to reduce the level of the kick, string, vocals, guitar, etc... so I compress it individually.
Once you've compressed the individual tracks that need it, and have mixed your tune. The compression you apply to the whole mix is a part of ... mastering. You'll need a multi-band compressor for that. I use Wave's C4 compressor, which has 4 bands such that the 1. low, 2. low-mid, 3. mid & upper-mid, and 4. high sections are compressed pretty-much individually.
ps. it may be different for non-urban music, but i never add reverb before i compress. i want to make those vocals sit pretty all by themselves before i go splashing effects around.
ps2. someone asked about plugins. I have waves, dsp-fx, and ultrafunk. I like the ultrafunk single-band compressor and EQ. I like the dsp-fx acoustiverb and studioverb, and I like the waves ultramaximizer and C4 compressor. I also use the Antares Autotune because I don't have perfect pitch, and as of yesterday the SpectR-Pro spectrum analyzer.
