FA Compressor
Anyone using the FA Compressor? Is it worth the $20?
I have used it. At $20 you can hardly go wrong. I don't use it anymore because I'm primarily using Cubase now, but I really enjoyed it when I was using n-track.
If you don't have a compressor I'd go for it. |
http://www.slackmaster2000.com/articles/freeplugs.htm
try some of the stuff here...you may be able to pick up something just as good for free...check out the Blue Line first..... that link is courteousy of the N-Track Moderator his majesty Sir Slackmaster2K...if you use his site he may require you to lick his boots and fix him chicken...... |
Definitely worth the $20. Much better than the compressor supplied with n-Track. Good to learn on.
Gidge, I have been using the Blueline stuff (probably from your recomendation way back when) and don't have too many complaints. Kind of woundering how the two compared.
I also have Flavio's compressor plug-in. Good one, worth the $20.
Its not a C1, but for the bucks it is very nice.
Tom |
I'm not a fan of the compressor. For a much better inexpensive compressor check out www.db-audioware.com
but how do you read it?
I've been using the FA compressor, but I can't figure out how to read the graph. What do the X and Y axis represent? The instructions that come with it are worthless. Can anyone help?
Try posting this as a new thread. I'd like to see the answers. I don't understand the graph either. The soft knee curve I could see, but that was about it.
On most compressors, the graph is represented as such:
x-axis = input volume y-axis = output volume So let's say you do 20:1 compression at a threshold of -10db. On the graph you'll see a nice linear line right up until -10db, at which time the line will shoot off horizontally very quickly. This is because for everything under -10db, the compressor will not change the output volume (disregarding release), but after -10db, the compressor will begin to compress at a ratio of 20:1. Hence everything over -10db is going to come out real close to -10db (disregarding attack) in this example (because the compressor will output +1db of gain for every +20db over the -10db threshold). That's the best I can do, if you want some real compression discussion, you might ask over in the mixing forum. Slackmaster 2000
Slackmaster 2000 |
#12
Thanks. What you said makes sense. Unfortunately, sometimes the graph seems to behave as you described it. At other times it doesn't. Weird. That's what I get for $20, I suppose.
