Drum Compression Help
I'm new to recording and need help with setting up my compressor. I'm using a cheap 5 piece Nady drum mic kit with a SM57 on the snare going into an Alesis 3630 compr. then in an Akai DPS16. I don't have a preamp. I've been using this setup for 3 months and can't figure the damn thing (compr) out. It's either too much or too little. I'm a solo artist and not a very good drummer. So the volume of my playing fluctuates a lot. A drum machine is not really any option for my style. Any help would be greatly appreciated.
Here's a sample song using this setup. http://www.maderainfo.com/push.mp3 Yes, I know the toms sound dead. The heads are ancient and dimpled to hell. I have bought new heads since this was recorded. |
Taking the 3630 OUT of your signal chain completely will help immensely............
Plug it in and use it on your desk as a colorful paperweight, or even a flashy doorstop (I mean, it does have all those pretty lights and all... it might as well be useful for *something*!) Bruce |
sell the 3630 on ebay and get a Behringer Autocom Pro ($79)...at least youll get a usable unit.....
New Compressor
Say, I do get a new compressor, any suggestions in a sub $300 unit. Maybe something tube? I still wouldn't know how to use the stupid thing. Did you hear my MP3? The snare pops in and out a lot. it's very uneven. I need help with settings.
I would say at this point a good drummer will do more for your recording than a good compressor.
You've four compressors in the AKAI DPS16 unit. Have you tried using them as well?
I tried to find some info about the mics you were using, is it Nady DMK-5 and the SM57? What are you using for overheads? |
"You've four compressors in the AKAI DPS16 unit. Have you tried using them as well? "
good idea...anyone out there hip to the quality of the Akai's compressor?....has to be better than the 3630.... |
Akai compressors
I'll try the built in compressors. Do I compress the drums on the way in or after they are recorded? If I do afterwards I'll loose at least two of my effects. I can only use four at a time as it is and the only outboard equip I have is the stupid 3630.
Nobody has answered my original question. What are some good settings to start with. Rght now I have it set like this..... Thresh= -30db • Ratio=3:1 • Attack= 30ms • Release=50ms. How far off the mark am I? Please give me some advice other than "get a good drummer" or "your equipment is a doorstop". I need real advice not bashing. Thanks again. Last edited by apush; 01-02-2002 at 09:55.. |
Mics
yeah, I'm using the Nady DMK-5 setup on 3 toms and the bass drum SM57 on the snare and 1 SM57 as an overhead. It's crappy, I know. But after spending all my money on the recorder, it's all I could afford.
Your settings will depend COMPLETELY on the signal you send into it... although 3:1 or 4:1 ratio is reasonable to start with - threshold depends on your signal level, and attack/release depend on the song's tempo to a certain degree.
I wouldn't track with compression, 'cos you can't undo it later if you fuck it up. Just as with a lot of other cases in audio engineering - a compressor is one of those devices you have to train your ears to use, because someone else's settings will NEVER apply to your situation. Bruce |
#12
So if Bruces RNC's settings work for him, it might not work for you. Close?...perhaps but not the same. |
#13
