Hi!I am using Cakewalk Sonar,and at the beginnig I could press the record button of the audio tracks,but now when I try to switch the recording button of a audio track it doesn`t work.
I can only record with the Midi tracks.I don`t know what to do! |
Are you arming the tracks? Is the source set to an audio input that has something coming through it?
Well, what is the track setup? What device is set as the default recording channel? If that is wrong then you will likely see the type of issue you are seeing.
