Old 12-25-2001
tellmey tellmey is offline
Newbie
tellmey is on a distinguished road
buzzing dmt 8vl
just bought a used dmt 8vl. when i turn power on the hard disk starts a rather loud whining sound. seems micing would pick up sound. when monitoring playback, i can't tell if it's on the track or not.
Old 12-26-2001
Henri Devill's Avatar
Henri Devill Henri Devill is offline
Newbie
Henri Devill is a name known to allHenri Devill is a name known to allHenri Devill is a name known to allHenri Devill is a name known to allHenri Devill is a name known to allHenri Devill is a name known to all
It will not make as much noise when it "warms up" so to speak..Once it hits the rpms{5400}of the drive, its fairly quiet..You can get viberation if it sits on a uneven surface causeing noise also..Put some tissue under the one of the rubber feet..The one under the drivebay{underneath in the middle} is usally the culprit..Should be fairly quiet then ..Good luck
Don
blessed are the cheese makers
Don
