Old 12-23-2001
Hob Hob is offline
Newbie
Hob is on a distinguished road
Computer or 16 track for recording accoustic?
I'm interested in beginning to record accoustic piano, and I'm wondering whether to buy a digital 16 track, or a computer with recording software. Would love your insight into the pros and cons of each. Thanks.
Old 12-23-2001
Garak's Avatar
Garak Garak is offline
Dedicated Member
Garak is on a distinguished road
If your background has todo with computers go with the computer based setup.
If your background is music then you might be better off with the 16 track recorder.
The main factor for me was cost, 16 track recorders can be very expensive compared to a PC. You can build a computer to handle 32 tracks + for under $1000. While most 16 track track harddrive recorders are well over $1000.
If your just recording piano you don't really need a big fancy setup nor 16 tracks. A small 8 track recorder would do fine or with a computer likely the computer your using now would be fine if you add a pro quality soundcard.
In recording piano most of your money should be spent on buying mics and preamps and maybe an out board compressor.
Old 12-23-2001
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
Garak pretty much summed it up inside of one post.
spin
Old 12-24-2001
dr.colossus's Avatar
dr.colossus dr.colossus is offline
Force of Nature
dr.colossus is a jewel in the roughdr.colossus is a jewel in the roughdr.colossus is a jewel in the rough
one point is that a console (be it eight or sixteen track) is by far more portable than a p.c.......but what garak siad is vrey important... if you never seen a tascam porta 02, then go with the pc, because once you get attatched to console recording its a hard thing to break out of....IMHO i think digital eight track would be suited down to the ground for the job (unless of course you feel you will need sixteen) then the money saved would be well spent on good mics, comps and pre's... just like garak said
Old 12-24-2001
Garak's Avatar
Dedicated Member
PC based systems can be quite portable they just cost a little more than. A rack mount computer chassy and keyboard drawer in a little rack. Add a flat panel LCD and its just as portable as any of the harddrive recorders.
I've dragged the PC with a 17" CRT to more live shows that the computer chassie actually fell apart.
