Old 12-22-2001
Recording Engineer Recording Engineer is offline
Moderator
Recording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond repute
Post 8 Ch. Parametric EQ & Near-Field Monitors For Sale
Kawai EQ-8 8 Channel Parametric Equalizer
This 1U rack module is a VERY versatile, fully parametric EQ!
Each channel has 3 Q (band-width) options with a cut/boost of -/+15dB at a user selected center frequency ranging from 50Hz-15kHz.
Also, each channel has 3 input level reference options. They are "L" for -10dBV, "M" for 0dB, and "H" for +4dBu. However, on channels 1 and 2, the options are "L", "M", and "MIC"; the "MIC" would be used for microphone levels. You'll find using the "M" (0dB) setting is ideal for most situations, but it's nice to know the other options are there if the occasion arises!
Please note that the input level switch on channel 5 is partially broken of and is set to "M" (0dB). An open saftey-pin could easily adjust it to "L" or "H" if you ever needed to. This really isn't much of an issue as once you set it for interfacing and application(s), there really isn't any need to change it.
There is a 1/4" input and output connection for each channel. So, it can be used as 8 separate, 1-band parametric EQ channels. However, if you only connect to inputs 1, 3, 5, 7 and outputs 2, 4, 6, 8, you then can use this module as 4 separate, 2-band parametric EQ channels. Also, it can be used as 2 separate, 4-band parametric EQ channels by connecting to input 1, going from output 2 to input 3, and out of output 4 for the first channel, and connecting to input 5, going from output 6 to input 7, and out of output 8 for the second channel.
Also includes the original Kawai Model PS-121U2 AC 120V power supply.
$80.00 USD
Pair Of EGO-SYS NEAR 08 8in. Passive Near-Field Studio Monitors
For complete information and specifications, please go to:
http://www.egosys.net/eng/product/pr...ar_08/N08.html
OR
www.egosys.net
These sell for over $550 new.
Not more than 1 year old and I guarantee that they are NOT blown.
$230.00 USD
jwbros@hotmail.com
