Old 12-22-2001
Recording Engineer Recording Engineer is offline
Moderator
Recording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond reputeRecording Engineer has a reputation beyond repute
Post 2 Condenser Microphones For Sale
1 Pearl CR-57 Transformerless True Condenser Microphone:
Polar Pattern Uni (Cardioid)
Frequency Range 15 ... 22000 Hz
Sensitivity 8 mV/Pa
Impedance 200 Ohms
Max. Sound Pressure Level with pad 150 dB
Dimensions 43 Ø x 220 mm
Weight 0.420 kg
This is a pretty rare microphone... I've only seen 1 or 2 of these around. Excellent condition for its age. Has a low-cut filter switch and a -12dB pad switch inside the housing. Can be powered with Phantom Power or a standard 9V battery inside the housing.
$275.00 USD
1 TOA Condenser Microphone Model RD-15C:
This microphone is a small diaphragm condenser (I believe a 1/2 inch) and is an interchangable capsule, screw-on type. I only have the cardioid capsule for it.
It is in good condition for its age. Guaranteed to not be DOA.
It works great, but make sure to use a windscreen or pop-filter in front of it if going to be used on vocals or in any type of environment where wind can possibly be blown into it.
$85.00 USD
Old 12-22-2001
Moderator
Arrow Forgot
Email me @ jwbros@hotmail.com
