I've got the chance of picking up a cheap active di box/splitter with multiple ins and outs for US$100 reduced from US$250, called Etek Multi Di (see specs and picture at www.soundslive.co.uk/1422.htm).
Just curious, are there many different qualities of di box (like there are mixers and preamps) or are they fairly standard accross the board? I need it for helping me get two direct lines from my guitar into my soundcard (via convertor box I should say) simultaneously with two or more mic lines from one or two amps connected to the guitar. I've always recorded a single mono signal from my guitar until now but want to experiment with different mixes of sound from - direct line in and mic. Any problems with quality of signal through a box like this do you think? - Phantom Power 48 V - External Power Supply 12 - 30 V DC - Electronically Input Balanced/Unbalanced - Switchable Gain 0 / -20 dB / -40 dB - Switchable Input Impedance 2K2 / 22K / 400K Ohm - Ground / Lift Function - Electronically Balanced Output - Output Impedance 100 Ohm - Freq. Bandwidth 5 Hz ÷ 40 KHz - Frequency Response 5 Hz ÷ 50 KHz - THD < 0.05 % - Dimensions mm 44 x 483 x 100 - Weight Kg 1.8 "It is possible to use the Multi Di to link 2 inputs with eachother and have 4 outputs with a single input. The link can be programmed by means of a switch. When the leds are lit it means the channels are active". Thankyou, if anyone uses these boxes and knows what to look out for quality wise. Nigel |
