.....i click the record botton in multi track mode. what i'm tring to do is record a vocal track on one track with an imported music track on another track....but i can't even get that far because as soon as i click on the record button CEP crashed and that annoying "this progam has profoemed an illigal funtion" message....what is causing this problem....is it windows 95 that i'm using.???
What is the exact error? Is it kernel32.dll ? Is it something else. You might look into upgrading or changing your Direct X, but I would probably think about upgrading form Win95 also.
MIKE |
Do you have a Full-Duplex sound card?..If not it may be crashing while trying to playback and record simultaneously..I had the same problem with Acid 2.0 back in the day before I knew anything about audio recording, sound cards, etc...If you don't have a full duplex sound card and you want to pick one up for next to nothing get a Soundblaster 16PCI at you local Wal-Mart for about $30..they work well for the cost
I had the same problem even though I had a Soundblaster card all i Did was put more memory in and got a bigger hard drive ever since I have no problem whatsoever. Ive been able to record up 10 tracks at a time with 3 as playback and it hasn't crashed. Try looking in to these fields as well. Good luck.
DIOXIDE "Ill make weapons from my imperfections" |
try reinstalling CEP.
xoox |
