Ok I'm playing around with the fruity loops program and i am loving it but when I export a wav. file into n-track it only plays for like 0.02 seconds. When I hit SHift-cntrl-v it play longer but you can hear little clips in between it doesn't play like a song. How do I get the fruity track to play like a song in n-track?
You need to create your entire song or track using a playlist. Then switch the playback mode from "pattern" to "song", and do your export.
Slackmaster 2000
Slackmaster 2000 |
Yes, I always extract my drum loops from Fruity or ACID in phrases of at least 4 to 8 measures or a track for the entire song.
Measure-by-measure will bring any sequencer to it's knees. |
there's an arrow at the top of the Playlist grid which I think you can use to loop your song. I've found with a wav. exported from Fruity to n-Track the wav. will only play to the point on the Playlist grid where this arrow is placed. Don't know if anyone else has had this happen.
