Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-14-2001
Rhino_Rick Rhino_Rick is offline
Junior Member
Rhino_Rick is on a distinguished road
Question Export Issues
No, I'm not talking about national exports or anything.
I completed a project awhile ago. It had lots of tracks. Probably 20 or so. And I hit the mixdown button because I wanted to shoot it all together into one wav file.
It would tick.. 1%... 2%... 3%...
and stop.
Eventually, Cubase would crash my computer.
THE WEIRD THING:
Sometimes it would work fine.
Does Cubase just need more Wheaties in the morning or am I doing something wrong?
"I am just a bug on the windshield of life."
Old 11-14-2001
Chriss's Avatar
Chriss Chriss is offline
Jitens Half Brother
Chriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond repute
needs more wheaties... definitely..
you could also try and make Cool Edit Pro or similar record it.. i allways do, cause cubase seems to be really buggy about the recording thingy...
Change the name to protect the guilty
You'll never leave Sin City
Where you are king
Old 11-16-2001
c9-2001 c9-2001 is offline
1K Silver Member
c9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond repute
i had that problem with my old computer. once upgraded it cubase ran fine. what type of system are you running...
Old 11-18-2001
Junior Member
AMD 1.4 ghz, 256 ram, 7200 rpm IDE HD.
Shouldn't be an equipment problem! That's why I'm bummed.
Old 11-20-2001
Mistral Mistral is offline
(Ill Omen Nation)
Mistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond reputeMistral has a reputation beyond repute
pretty odd.
I have 1 ghz PIII, export works fine here.. do whatever you can to optimize your system itself.
1. What OS are you running? I use Win2000. Works great, cept for the odd random crash, but as far as stability goes it's the best I've seen, for Windows anyways.
2. Get FreeMem Pro if you don't have it.. makes sure that your system is always freeing up whatever RAM is available.
3. Make sure your unnecessary apps are closed.
4. Make your Windows SWAP file a fixed size. That is, the min and max settings are the same. I have the same RAM as you, 256.. I set my swap file at 400 mb.. Cause well, I have 50 gigs of HD. Anyways this will keep your system from slowing down too much while changes are made to that file..
5. 20 tracks at once should be ok but do you have them all loaded with FX/EQ's/VST instruments? Even a 1.4 ghz with 256 ram has its limits. make sure you don't have more going on than you need to.
Just my suggestions..
http://www.ryosa.com - subscribe to my twitter feed to immediately see when I release new stuff.
