Go Back   Home Recording > User Forums by Brand > Sony Tools / Sonic Foundry
Reply    Audiofanzine Sony Sony News Sony Medias Sony Tests Sony Articles Sony User Reviews Sony Classifieds Ads
Old 11-10-2001
czar of bizarre czar of bizarre is offline
Dedicated Member
czar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these parts
Question guys i NEEEEEEEEED your help pleeeeeeassse!!!!!
guys im trying to do something sooooo simple but i cant seem to get it done. what i want to do is SYNC acid 3.0 with my roland vs880ex. i want to RECORD the vs tracks into acid. i have my sound card set up and im going in DIGITAL. however here is the problem. i want to be able to hit RECORD on acid and have the vs stuff playback. where are the settings that i need to change on acid to make this possible and what should i set my vs to?
thanx.
czar of bizarre
ps i am bizarre
Old 11-10-2001
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
What's up C.O.B.
I don't have Acid in front of me at the moment, but you need to set Acid to generate MTC or MIDI CLOCK (I'm not sure which one the VS880 responds to...).
OPTIONS>PREFERENCES>SYNC tab
Set-up Midi Time Code device (generate), Midi Clock (generate), Midi Time Code (chase).
That should do the trick for ya'.....
peace...
spin
Peace...
spin
Old 11-10-2001
Dedicated Member
when i checked the vs MIDI settings it had mmc (master,slave and off)
when i checked the vs SYNC/TEMPO settings it had MIDI CLOCK and MTC.
i know how to make the vs send messages to the xp60 and have it play back.......hey....... so what would i need to do???
czar
Old 11-11-2001
theglitch theglitch is offline
Here and there poster
theglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond reputetheglitch has a reputation beyond repute
czar
You may already be aware, but the VS must be in SLAVE mode. As stated above, set the software to output timecode and that should be the extent of it. Call Roland's tech support if you still have problems.
Matt
No clever saying.
Old 11-13-2001
C.O.B., you need to find out which one the VS responds to (MIDI Time Code or MIDI Clock). It should be in your documentation. If you can't find it OR you don't have it, then you could [B]probably[/B} go online to the Roland site and check the manual. Once you've figured that out, you must tell the VS to be the SLAVE unit instead of the MASTER unit.
So.... Acid (MASTER), VS 880 (SLAVE), XP60 (SLAVE)
peace...
spin
Peace...
spin
