Thread Tools | Display Modes |
using motu mkII and cubase 5.0 and P3 500 w/ 394 mb ram...
I cant figure this out please help!!!! I think it has to do with buffers or cache or something like that maybe.. |
yup, it's prolly a buffer error.. you need to make it bigger... the buffer that is...
In Options - Audio Setup - System - Asio Control Panel You'll see a little square called "Buffer" in your Playback Device window. You can click the number underneath and make it a little larger progressively till you don't get any more clicks and pops... What software instrument are you trying to use along with cubase? It could also be a matter of clattering voices or too much vst action at once, but i doubt it...
Change the name to protect the guilty You'll never leave Sin City Where you are king |
no software instrument. I am trying to get 16 tracks of adat dumped into cubase for mixdown and editing. i tried doing just one track and got the same result so I knwo it cant be a overload on the resources.
what is the downside of raising the buffer level? Will this affect the monitoring on overdubs (latency)? |
ohh.. on record? then you need to raise the Record Buffer size..
Doing it will cause higher latency in the recording, but it won't have any effect on the sound of the result. I suggest you also try changing the Asio Device... what soundcard do you use?
arrrggghhh i'm blind!! I can't see!! arrgghh... motu...
yeah I find it hard to believe this expensive card needs such a high buffer... that is really disapointing. If this means I cant do overdubs due to latency then something has to be wrong. Surely no one would buy this if it was basically useless!
how much latency does it show?
well I tried adjusting the buffer on the asio/motu card and it was better but still the problem continues.
I think I am going to have to find someone that really know these configs and probably pay them to look into this for me. what a dissapointment.. damn. |
in Options - Audio Setup - System... under the button saying "Asio Control Panel"
that I think is the buffer setting if I am not mistaken. There two buffer adjustments I see there. One as the system (128) and then on the asio control part I also have it set at 128 but I also set it to 256 but no go. same stuttering or halting on record. Even if I narrow it down to just one track.
I wonder if the data drive I am storing to is not actually running in DMA mode. i dont knwo how to check that though |
