Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-02-2001
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
noise gate on kick
Anyone tried a noise gate on a kick drum? I'm tired of having others drums come threw on the kick track. I use either a Senn 421 or a Beta 52 on the kick,into a ART PRO VLA into the console then the ADAT'S. I've tried gating the snare also. I'm trying to get a little more control.
Old 11-02-2001
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Sure! Just get your threshold, attack and release right so that you don't lose any of the kick parts... it'll work fine.
Bruce
Old 11-02-2001
vox's Avatar
vox vox is offline
Force of Nature
vox is on a distinguished road
Some people will throw a blanket over the kick to tame some of the leakage.
Old 11-03-2001
Tom Hicks's Avatar
Tom Hicks Tom Hicks is offline
1K Silver Member
Tom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant future
Phil Collins was famous for gating his drums.One of his tricks was to have a distant gated mike in addition to the close mike when recording in a large acoustic space.It made his kick sound huge.
Tom
Old 11-07-2001
Gargamel's Avatar
Gargamel Gargamel is offline
Dedicated Member
Gargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond reputeGargamel has a reputation beyond repute
Check out the song 'Eye of the Beholder' by Metalicca. Its on the Album 'And justice For All"....crazy kick!!!!
Old 11-10-2001
ametth's Avatar
ametth ametth is offline
Sir Cool of Coronado
ametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond repute
Before a gate, I would try for better placement of the mic. I personally dont use gates at all. What kind of leakage are you getting? Why not make it work for you?
yep.
Old 11-10-2001
jmorris's Avatar
problems
Well,my problems are too much sound other than the kick comming threw. This is only a problem is someone wants to use say,my dm5 drum unit. I try to run a patch from the kick channel to trigger the sampled kick. I get false triggers at times.Ive used a gate to reduce the ring on toms and to get rid of unwanted hihat on the snare track, For snare now I try to mic right under the hihat,trying be as oposite the hihat as I can.
Old 11-14-2001
aheard69 aheard69 is offline
Newbie
aheard69 is on a distinguished road
its all trial and error....if your original signal is good then it will be easier than if you original signal is weak...try mixing it without a gate and if really need one..set the level so low that you can hear everything being picked up and just edge the gate in so it slowyly starts to remove the other parts of the kit..dont use excessive gating or you'll lose all the feel of the kick.
