Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 10-30-2001
otherness otherness is offline
Newbie
otherness is on a distinguished road
Cool balanced and unbalanced
What is the difference between balanced and unbalanced microphones?
Old 10-30-2001
ametth's Avatar
ametth ametth is offline
Sir Cool of Coronado
ametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond reputeametth has a reputation beyond repute
(edited)
yep.
Old 10-30-2001
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
Not balanced or unbalanced microphones,more like the cables used to connect the microphones. a balanced cable contains a 1/4 inch balanced plug ( tip,ring sleeve) or XLR connector (with 3 pins )which contains a hot lead for grounding.
Unbalanced cables contain a 1/4" plug that contains only a tip and sleeve.
Most cheap mics (Radio Whack comes to mind) comes with unbalanced cables for connectors, though balanced XLR and cables can also be used (as evidenced by the 3 pins at the bottom of the mic)
Old 10-30-2001
ametth's Avatar
VERY SIMPLIFIED EXPLINATION: The piece of equipment
sending the signal splits it into two signals (lets say '+' and '-' for S&G) and inverts the second one. The recieving piece of equipment inverts this second signal back to its initial phase and adds it to the first one. Any noise from the cable that is picked up is effectively cancelled out when the second inversion occurs.
yep.
