Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 10-27-2001
PG13 PG13 is offline
Senior Member
PG13 is on a distinguished road
Cubase 5 question
I have a an AMD mother board and processor 800mhz
with a soundblaster live 5.1 Souncard when every i record with cubase or logic i hear a 1/2 second delay with my vocals when im flowing and it really throws me off what would be a solution to mt problem is it the sound card?
Old 10-27-2001
Chriss's Avatar
Chriss Chriss is offline
Jitens Half Brother
Chriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond repute
My suggestion: Throw Creapative SBlive out the window and get a card with som real ASIO drivers...
Anyway... even on SBlive you should be able to use some ASIO.. so in cubase, go to Options, Audio Setup - System and in the upper right corner of the pop up window, you'll see a place saying "Asio Device"
Right underneath you'll find a text saying "Latency XXX Miliseconds". The number in the XXX field should be as little as possible, try and choose a different ASIO device and see what happens. Usually the best will be the one saying, "ASIO DirectX....."
this might add a little extra.. I'm not too familiar with SBlive 5... but...
Still in the same screen, click on "ASIO Control Panel" and check the top window in the next screen. That's your audio output device. You'll find a small box saying "Buffer Size"... The smaller the Buffer, the shorter Latency, but too little a buffer can cause some serious audio fuckups. So try messing with it.
I have my buffer set to 1024 samples, and it's running with 24 ms latency. It could be smaller, but I don't wanna tempt faith...
hope that helped
Change the name to protect the guilty
You'll never leave Sin City
Where you are king
Old 10-28-2001
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
I'm using a Tascam US-428 and it has a similar "problem"- I can hear what I am recording just a little too late and too loud to concentrate.
I just mute the track that I am recording in the Cubase mixer. It still records just fine, but it doesn't play back through the soundcard during recording.
I'm also recording and playing back through an external mixer, so I have the orginal signal from the mixer to use as reference when recrding with headphones on. No nifty real-time effects, but it works OK for tracking.
Take care,
Chris
Old 10-30-2001
Neosonic Neosonic is offline
Newbie
Neosonic is on a distinguished road
Yu Need the Asio drivers for Sound Blaster check this:
http://come.to/sblive
Saludos from Chile
Ne0SoniC
