Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-21-2001
BBB's Avatar
BBB BBB is offline
Force of Nature
BBB is on a distinguished road
How 'bout them BGW power amplifiers...
A few posts ago, Sonusman recommended getting a used power amp for PA applications. So I started scouring around for amps, originally considering the Peavey CS800 because my bands used them in the 90's.
A reliable salesman recommended a used BGW 750C over the Peavey. He mentioned that BGW had a good reputation in the 80's or so (and that's about how old this amp appears to be).
He's going to hook the amp up to some Community CSX57 speakers so I can test the setup.
Does anyone have any experience with the BGW amps (or the Community speakers)? Any suggestions on how I should test the combination.
Btw, the speakers are floor models for $649 and the BGW is $249.
Thanks,
-B
-B
Old 10-23-2001
thornapple thornapple is offline
Newbie
thornapple is on a distinguished road
Here's a point a lot of people over look. SLEW RATE!! This is how quickly that amplifier is going to respond when a high level of voltage is seen. Example metal kick drum is a fast and big signal on an amp. Try a signal like such and the only difference is swapping the amps. A peavey will sound compressed and mushy sitting next to a crown of the same power. There are plenty of good deals around on used crown amps. I have used theese in STUPID places. Under powered, over powered, Had one that during a rain storm and poor run off it was completely under water and still working fine. Best Bang fo Th Buck Go CROWN
Old 10-23-2001
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
In addition to Crown...
...there's also Hafler (P-series & above), Bryston, QCS...
Bruce
Old 10-23-2001
Hmmm - I've never heard of BGW... but they have a website....... http://www.bgw.com/amplifiers/professional/750.asp
Bruce
