Old 10-02-2001
Whyte Ice Whyte Ice is offline
The Next Vanilla Ice
Whyte Ice is on a distinguished road
Drum Miking With 4 Mics
I've been doing some drum recordings lately and its been very tough getting a good sound (especially out of the snare). I can only use 4 mics since there is only 4 inputs on my mixer.
The mics that I have are Shure SM57, Unknown Really Good Kick Drum Mic, Superlux CM-H8A Condenser, Studio Projects C1 Condenser.
I setup the SM57 on the snare, the kick drum mic on the kick drum (of course), and the condensers as overheads (one on each side).
My drum set consists of a Snare, Kick Drum, 2 Rack Toms, Floor Tom, Hi-Hats, Crash Cymbal, and a Ride Cymbal. I can get a really good sound out of it when I'm playing but whenever I listen to a playback of what I recorded it sounds like total crap.
I spent almost two hours tweaking the levels, mic positioning, etc. and I still wasn't getting the sounds I was hearing when I was playing. The biggest problem is the snare, it sounds great when your playing it, but when you listen to the playback it sounds like a big thump.
I don't know any more information I can give, but all I want to know is what am I doing wrong?
Old 10-02-2001
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
FIRST ADVICE.....Dont get discouraged......ask some of the big boys here and they'll tell you they spend 1-2 DAYS getting a drum sound before they even attempt to roll tape......
the sm57 is pretty standard for a snare so I would guess that it isnt your culprit.....it could only be positioning, the room, the mixer, or the recording medium......
have you tried these...
http://www.geocities.com/shailat2000/MixingDrums.html
http://homerecording.com/bbs/showthr...ighlight=drums
Old 10-10-2001
frank_1's Avatar
frank_1 frank_1 is offline
Force of Nature
frank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond reputefrank_1 has a reputation beyond repute
The truth is that you can get a good sounding set using only 4 mikes. Kick, Snare, and a pair; as the old saying goes. Ask Bruce, sonusman, or sokojo2.
First check this out....
Old 10-11-2001
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
First - the o/h's are going to be responsible for giving you a significant portion of your drum sound. The close-mics on the kick and snare will add color and accentuate what is already present on the o/h's.
Second - the kit needs to sound good before you even throw any mics up.
Third - check for phase issues between the close mics and the o/h's.
Fourth - take the room out of the equation a bit by putting up damping blankets around the kit and even more importantly, on the ceiling over the top of the drums (staple-gun...)
Fifth - play with positioning to get the sound you want first, but you may still need to use EQ (a little bit!) to tweak the sounds...
Also - you never mentioned what you're recording onto and what kind of mixer or mic pres you were using... these will also be factors.
Bruce
Old 10-11-2001
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
I dont totaly agree with Bruce on getting the major part of your sound from the OH if the drums are close miced.
It depends on style of music as well as how imporant a part is the snare in your song.
Every thing else he wrote is solid.
Discribe for me more - how does the snare sound as compared to what you want. "Big Thump can mean a lot of things.
It might be a small problem of distance from snare.
And it might be a big problem with EVERY THING else.....
Record the snare drum alone with out the kit and listen. Then tell me.
Old 10-13-2001
cwillu cwillu is offline
Senior Member
cwillu is on a distinguished road
Well, if you've only got 4 mics, we won't be talking about close miking
And not that there's anything wrong with 4 mics...
Little tip I've found useful, at least for a start: find a friend who can pound the drums for you a bit, and a good set of headphones. With only the overheads on, turn up the phones so you can hear them clearly from the kit itself, and move the overheads around while listening through the phones (take 'em off every few moments to remind yourself of the sound your going for). Repeat adding the snare, then the kick to the mix... this should give you a good start.
cwillu (my bi-annual post )
Old 10-13-2001
I agree completely! (but thought it was implicit that it always depends on the situation, so I didn't think to add "...in many cases, 70% of the sound... etc..."! )
Bruce
