Old 09-27-2001
kristian's Avatar
kristian kristian is offline
1K Silver Member
kristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond repute
what are the actual dimensions of a 2x4?
1 1/2 x 3 3/8?
Old 09-27-2001
barefoot's Avatar
barefoot barefoot is offline
barefootsound.com
barefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond repute
1 1/2 x 3 1/2
Old 09-28-2001
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
And you thought software companies were the only ones to lie about their specifications?????
Old 09-28-2001
sjoko2's Avatar
sjoko2 sjoko2 is offline
who knows?
sjoko2 is an unknown quantity at this point
2 x 4 is the "rough cut" dimension. After that cut has been made the timber is planed down to 1 1/2 x 3 1/2 for "normal" timber. Kiln dried 2 x 4's are a fraction smaller.
Being European, you mentioned the reason I really screwed-up the first design job I did in the US, I had to re-do the drawings for the framing, soffits etc. Fortunately someone pointed it out to me before the building started.
Old 09-28-2001
muzeman's Avatar
muzeman muzeman is offline
1K Silver Member
muzeman is on a distinguished road
Smile
I've seen 2x4's vary in size on the same stack from the yard,from 1 3/8 to1 5/8 and 3 3/8to3 5/8.
I usually go with 1 9/16 x 3 9/16 when adding them together.
This is rough lumber designed for framing and made to be covered by another surface,usually has a high moisture content,(in the winter you get it delivered covered with ice),so if you use it for critical projects inside when it dries out it is going to twist,warp,crack and check.
You can either leave it inside for a week or two then plane and joint it if you have access to these machines,or by #2pine of the same dimension,it is dried and surfaced to exact dimensions.
Pine is sold in 1/4s-a 2x4 would be 8/4x4.
Rough lumber(usually) is milled to the 1/2 ie:2x4&2x6=1 1/2x3 1/2 and1 1/2x5 1/2 until you get to 2x8-2x12 then its milled to the 1/4-1 1/2x7 1/4ect.
Man thats enough of that I'm starting to feel like I'm at work(anybody got an asprin my heads startin to kill me)
Good luck,
Pete
Pete
