Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 09-27-2001
Henrik's Avatar
Henrik Henrik is offline
Dedicated Member
Henrik is on a distinguished road
Midi events
Hello,
I'm looking into buying a hardware sequencer for live use. All manufacturers rate how many events their sequencers can store in the internal memory. For instance the Roland MC50 can store 40,000 events.
But I wonder what that means precisely. First - do both note on and note off count as an event (so hitting and releasing a key uses up two events)? But more interesting: Say you have a drum sequence that takes up 40 events. If you play that 50 times in a song, is the memory used still 40 events (plus the used memory for the information that the machine should repeat the sequence), or is it 40x50 events=2000 events?
Thanks
/Henrik
Old 10-01-2001
robsmusic's Avatar
robsmusic robsmusic is offline
Newbie
robsmusic is on a distinguished road
Note on and note off are 2 midi events.
Continuous controllers (pitch bend and mod wheel, etc) use multiple events depending on the amount and length.
On most sequencers, a looped 40 event passage would still use only 40 events, regardless of the number of times it is looped.
If the passage is recorded linearly, or copied and pasted to make a longer passage, then the number of events would increase. So, to use your example, a 40 event passage pasted 50 times in a row would create 1 passage of 2000 events.
HTH,
-Rob
Old 10-02-2001
Henrik's Avatar
Dedicated Member
Great, thanks! That's what I thought.
Cheers
/Henrik
