Old 09-15-2001
reco's Avatar
reco reco is offline
Registered User
reco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond reputereco has a reputation beyond repute
My new pad!
Hey yall Im workin on my new studio.
I live in the sticks, I got A load of valted trusses for free(messed up order).
And a but of lumber that was being cleared from a lumber yard that my friend works at.
I am building it on a slab(floating).
It will be a free standing building(30x25or30FT.)
I will post shots as its going up.
Old 09-16-2001
sjoko2's Avatar
sjoko2 sjoko2 is offline
who knows?
sjoko2 is an unknown quantity at this point
cool!
How are you going to build a floating slab?
Old 09-16-2001
langleyt langleyt is offline
Dedicated Member
langleyt is on a distinguished road
Great! Will be waiting for pictures of your progress. By slab do you mean cement? Not sure about the floating part either.
t
Old 09-17-2001
reco's Avatar
Registered User
uh?
By floating I mean that were not digging frost footings.
We first tore up the sod with a trackor.
And we have a Bobcat coming to leval the ground out.
Then we will bring in a load of sand and leval it out.
then we will set for the slab(cement) to be poored, and then we will wetset a course of block and after thats set for a while.
we will start on walls and the trusses and so on and so on.
Old 09-24-2001
sjoko2's Avatar
who knows?
Make sure you fill the block - use grout or rendering mix, not sand
Old 09-26-2001
Todzilla's Avatar
Todzilla Todzilla is offline
Force of Nature
Todzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond repute
Why not Sand?
Why not sand?
My builder is just about to get the backhoe in to start filling the cinder blocks with sand...
Insect Massage Therapist
HUGE sound generation & capture facility
http://www.toddejones.com
Old 09-26-2001
sjoko2's Avatar
who knows?
Sand causes considerable problems over time. It dries out - so the smallest little crack and the sand starts pooring out. Secondly, it settles with time, leaving voids at the top. Of cause if the first thing happens these voids get bigger and bigger.
I've had to deal with numerous cases over the years where the acoustic integrity of a place got bad, where sand was the problem.
If you fill it with rendering, you ensure everything is filled, it dries and it will not move. Rendering being rayher 'rough" it will enhance the acoustic properties of the wall.
Old 09-30-2001
reco's Avatar
Registered User
question?
were only laying one course of block do we realy need to core fill the block?
also what is it you said to fill it with? is it a mix of cement or what?
Old 09-30-2001
sjoko2's Avatar
who knows?
Originally posted by reco
question?
Answer to #1 - filling the block will give you far improved sound insulation.
Answer to #2 - the best thing is to use material which sets, so it won't put pressure on the block and eventually crack it (like sand can do). The material to use is whatever is cheapest available, which normally is large bags of grout mixture, or external rendering like for instance stucco base
Old 09-30-2001
Dedicated Member
Stucco, or one good coating of plaster? I have now idea what i am talking about.
t
Old 09-30-2001
sjoko2's Avatar
who knows?
Talking
That's ok langleyt sweetie, you just put one coat of plaster on the inside of each concrete block
  #12
Old 10-01-2001
Todzilla's Avatar
Force of Nature
Damn. My builder has already ordered the sand for the block filler. One thing that may mitigate sjoko's concerns is that the builder plans on stucco'ing both interior and exterior of block. I hope that will prevent any sand spill through. I assume his stucco compound will have enough elastimers to be forgiving.
As for the settling of the sand, I am going to ask him to leave a way to access the voids for any extra filling down the line.
I am still hopeful that a searing amp and/or a meat-eating drummer will produce only a distant thud in the main house, about 50 feet away, such that a radio on medium low will drown it out.
THNX
  #13
Old 10-01-2001
sjoko2's Avatar
who knows?
I'm not saying it will be a disaster - just take extra care, like inspect the mortar etc. The problem is that builders really don't know about acoustics.
