Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-14-2001
Salvadore Salvadore is offline
Junior Member
Salvadore is on a distinguished road
Angry useing 5 mics on a kit HELP
ok i have a 5 piece pacific percusion drum kit a basic kit 14 snare 12,13 toms 16 floor 22 bass and for cymbals i have 14 hi hat 16 crash 17 crash ride 14 chinese 18 ride. Now i only have 5 chanles that i can use to record the drums and cymbals what do you think would be the best mic configuration.
Old 08-14-2001
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
2 Marshall MXL603's as overheads
1 Shure sm57 on snare
1 AKG D112 on kick
if you have another condenser laying around, try it out front for ambience but not necessary.......
Old 08-25-2001
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
Smile
You really have to taylor the mics to the song, you dont' want to mic a drum that will not be used in the song. If you are short mics and one drum is used very little in the song do not mic it. you can come back and record it later. Beyond that Shure SM-57 mics are very versital for snare/toms/floor toms. Shure and AKG both make very good kick mics. I do not like to use condensor mics for overhead. they pick up everything and can make your cymbal track unusable. I would pick the cymbal that will be used the most in the song and us a directional mic.
PS I do not know if you have ever recored drums before, there is much more to it than mic selection. If you would like more info let me know.
Old 08-27-2001
gnarled gnarled is offline
Dedicated Member
gnarled is on a distinguished road
Originally posted by Freudian Slip
[B I do not like to use condensor mics for overhead. they pick up everything and can make your cymbal track unusable. I would pick the cymbal that will be used the most in the song and us a directional mic. [/B]
Huh?
With a well tuned kit and a good sounding room, a decent pair of overhead condensors can MAKE your drum recording. If you use good mic placement to get the snare centered in the mix, you'll find your self just bringing in the close-mics to fill it up a little if at all.
Or, you can close mic and gate EVERYTHING rendering all ambience obsolete and then use a crappy reverb plugin to try and pump some life back into it.
Better yet, just use some canned drums.
Old 08-27-2001
Source Of Confusion
Smile maybe so? I have a terrible room at the moment though.
The room I am in has no deadening. If I had a larger room to work with and some absorbtion I might be able to do what you are saying. I'm no expert all I can tell you is my own expierance.
The kick & snare came through the condensors so much when I tried it that I could not use the track. I like having the ability to mix the drums individualy as much as possible. If you have any suggestions I am more than willing to listen. I know deadening the room is one thing I have got to do. Right now It is working for me but I have more tracks to play with than our friend.
Old 08-28-2001
Bedubs Bedubs is offline
Newbie
Bedubs is on a distinguished road
I use a similar setup to what's been identified here but instead of two condensers as overheads, I have another SM57 between my floor and mid tom. This is because I have 3 cymbals (ride, china, crash) on that side and I think it allows me to capture my ride better than just the overhead.
Although using a condenser as overhead does pick up a lot of room noise and stray sounds. I have tweaked (positioning in room, on kit, volume, etc..) mine to where it doesn't pick up the other drums enough to make a difference but still adds to the cymbals. I also like being able to capture the "out takes" as we put some new toonage down.
-b
Old 08-28-2001
SpamBurglar's Avatar
SpamBurglar SpamBurglar is offline
Newbie
SpamBurglar is on a distinguished road
I would definitely go with:
1 mic on kick
1 mic on snare
2 mics in stereo as overheads
I've noticed that the overheads seem to pick up more of the mounted toms than the floor tom. You could also put a mic between two closely spaced toms and move or aim an overhead at the unmiced tom. I think it's good advice to mic up the most played drums. If you ride on your floor tom alot, I would mic it. If you don't play toms on a song, try mic'ing the hat - I had an extra channel on the last recording my band did and I mic'ed the hats. I am suprised how much I like having the option to mix in the hat mic to the mix.
Good luck.
Old 08-28-2001
Source Of Confusion
more in depth do you even have condensor mics? If not I would put a mic between the high hat and the snare pointed at the snare but right under the high hat adjust the high hat or mic to get the mix you want there. Of course mic the kick about 3-5 inches in from the front pointed a few inches off center from the beater(adjust for attack). if you can get your toms close together try micing down the middle rais the mic about 3 inches of the head to get both drums and then adjust the mic to get a close to equal signal from both toms. if you are not going to use the floor tom use 2 mics up top between and above the cymbals also checking signal for what you want. if the floor tom is important in the song I would mic it, maybe try to catch a symbal with it and then I would favor the ride cymbal with the other mic unless tom or floor tom mic is cathing it good.
now record do a rough mix and readjust as needed.
If you know the polar pattern of the mics you have you can choose wisely there placemet for the best results.
If you do not know about polar paterns and mic types
go to www.pcrecording.com there is an artical with a link that sums it up. I think the link goes to AKG so you might look there.
Good Luck.
Old 08-28-2001
Gidge's Avatar
Lapdance Test Dummy
Cool
or check out this thread..it is legendary....
http://homerecording.com/bbs/showthr...threadid=27030
Old 08-29-2001
iancade iancade is offline
Newbie
iancade is on a distinguished road
I close mic all of the drums and use a decent amt of EQ shaping via parametric EQ.I also gate and compress toms,kick and snare!
My mic selection includes:
Beta 52 on kick
SM57 on snare
AT Pro 25's on toms
SM 94's on hats and ride which also pick up other cymbals quite well.
Here's a site I found recently that pretty much follows my way of thinking on mixing/processing my drum kit!
http://www.geocities.com/shailat2000/MixingDrums.html
