Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-09-2001
msilva9383 msilva9383 is offline
Newbie
msilva9383 is on a distinguished road
What exactly is compression and how do I use it?
Hey,
I've heard a lot about compression and I still don't know EXACTLY what it is. Can anyone help me out? Like giving a definition or maybe an article explaining it. Also, what is mastering exaclty? Is it just making your mix loud enough to put on cd? Because thats a problem I have with my songs is that theyre never loud enough or some parts are too loud and others aren't loud enough.
Thanks,
Matt
Old 08-09-2001
zoetrope's Avatar
zoetrope zoetrope is offline
Senior Member
zoetrope is on a distinguished road
Compression is . . . never having to say clip
Start here --> http://www.studiocovers.com/articles3.htm
Let me know when you finish reading all that.
Done? Ok. Compression reduces the volume of the loudest parts of your song or track so that you can then normalize the track and bring up the overall average volume. Or something like that. Now read all those articles again.
Old 08-09-2001
dobro dobro is offline
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
Compression reduces loud peaks in your recorded tracks by a fixed ratio. You decide at what loudness level you want the compression to kick in - that's called the threshold. You decide how much compression you want to apply - that's called the ratio. A ratio of 2:1 means that as soon as a signal crosses that threshold you dialled in, for every 2 dB of gain, the compressor outputs only 1 db; if the ratio was 3:1, 3 dB of gain would output only 1 dB, and so on. Common ratios are between 2:1 and 4:1 - you don't want to compress stuff unless you have to - it's common to compress vocals, acoustic guitar, bass - the compression controls sudden volume peaks. You have to learn about attack and release times too, but that's another day.
One major result is that after compression, your track has less amplitude, less distance between the loudest and softest sound. One way that this is used by the crazed engineers of today's recording industry is that this 'squashed' track can then have its volume increased without danger of distortion, making the music louder overall.
Mastering is fine-tuning a mix, usually using EQ and compression and maybe some reverb, adjusting levels. It's final stage polishing. In the recording industry, it's done best by people with LOTS AND LOTS AND LOTS of experience and Very Expensive Equipment. You can try to master you own mixes, and it'll be a learning experience, but you won't come close to the pros.
Old 08-09-2001
zip's Avatar
zip zip is offline
1K Silver Member
zip is on a distinguished road
Uh oh.....Ed's favorite subject! Ed loves loud mixes...
To be honest dobro...."crazed" is just the right word. Overuse of compression during mastering just kills the dynamics of a good mix. Just my somewhat educated HO.
BTW...good description of compression.
Damn...I had another good link to Shailat's compression article...the one with examples...and it's gone!
PC has a mind of it's own.
zip >>
"Look around - Hear the sounds..." ~ Mike Portnoy
Old 08-10-2001
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
www.geocities.com/shailat2000
Old 08-10-2001
zip's Avatar
zip zip is offline
1K Silver Member
Shailat...thanks man...
bookmarked...again!
Ed,
I know bro...see the wink??
You have a cable modem Ed?? I'd like to send you an MP3 of what has to be the loudest...most compressed / squashed commercially mastered CD I have ever found! It's off the charts on my editor...you'd get a kick out of it! Right after you puked!!
zip >>
Old 08-11-2001
Elle Elle is offline
Junior Member
Elle is on a distinguished road
Dobro,
I agree about the mastering, I've finally have gotten to the point where I am asking myself what formatt my tracks have to be in if I want them professionally mastered?
I do not have and Adat. I could save each track as a wave file though.
Does anyone have any info on this topic?
Thanks!
Old 08-11-2001
zip's Avatar
zip zip is offline
1K Silver Member
Elle...
The mastering house should be able to master .wav files burned to a CD. I believe they should conform to Red Book specs.
Do a search on Red Book and see what the requirements are.
Rememeber...don't use cheap discs... Burn as slowly as possible (1X or 2X) onto a high quality disc such as a Mitsui. This keeps your error rate down.
zip >>
Old 08-11-2001
Junior Member
Thanks for that info Zip >>
Old 08-11-2001
zip's Avatar
zip zip is offline
1K Silver Member
No problem...
If you find some info on red book (a link) maybe post it back here. I need to know more about it anyway....
zip >>
