Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 07-23-2001
nuss nuss is offline
Junior Member
nuss is on a distinguished road
+48v buzz problem
I hope someone can figure this out.
I have a Behringer MIC2200 mic pre and as soon as i engage the phantom power w my AKG C1000s, i get a horrible humming buzz.
I know that it is not a problem with my mic cause i can use the phantom power from my console and it is noise free.
Could it be possible that the cable run is too long for the behringer to adequatley send the voltage? (cable run is almost 120')
Any other suggestions (other than the obvious:Behringer is broken) would be greatly appreciated!!
Thanks!
ME
Old 07-23-2001
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
It's DEFINITELY NOT supposed to do that....
Try a shorter cable and if it still does that - your Behringer IS broken...
Bruce
Old 07-24-2001
enemyofthesun's Avatar
enemyofthesun enemyofthesun is offline
Dedicated Member
enemyofthesun is on a distinguished road
is the device (preamp) producing the 48 grounded properly? I had this problem before.
Old 07-24-2001
jgourd's Avatar
jgourd jgourd is offline
The "Good" Sound Guy
jgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond reputejgourd has a reputation beyond repute
Are pins 1 & 3 crossed in one of the cables used to make a 120 ft run?
Old 07-24-2001
Junior Member
Hmmmmm.....grounded properly? Whats the easiest way to check that?
Shouldnt be....my console +48 works fine on the same cables.
Now Im wondering about the ground.........................
ME
Old 07-25-2001
Harvey Gerst Harvey Gerst is offline
Huh ???
Harvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond repute
The 48 Volts of Phantom power is DC so that shouldn't be the source of the buzz. With the cable plugged in at the mixer end (phantom power on), and no microphone connected, you should get a reading of 48 VDC between pins 1 and 3, and a reading of 48 VDC between pins 1 and 2. There should be very little (if any) voltage between pins 2 and 3.
Wwith both ends of the cable disconnected from the mixer and the microphone, you should have a continuity reading of close to zero ohms between pin 1 at one end of the cord and pin 1 at the other end of the cord (a dead short). There should be no reading between any of the pins.
If your cable run is made up of several shorter cables, start with just one cable and keep adding cables till the buzz appears - when it does, that's the bad cable.
