Old 07-20-2001
zip's Avatar
zip zip is offline
1K Silver Member
zip is on a distinguished road
Can you DELETE track automation or can you only edit it??
If you mix down using the automated mix feature can you delete it?? I saw an edit function but since my final output clips a bit I want to start over with the entire mixdown process. Is this possible? Not needed??
zip >>
"Look around - Hear the sounds..." ~ Mike Portnoy
Old 07-20-2001
Tekker's Avatar
Tekker Tekker is offline
1K Silver Member
Tekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond reputeTekker has a reputation beyond repute
Are you using Sonar or PA 9? I don't know about Sonar, but in PA 9 if you go to the Event List view for the track you want to delete and there is list there of your automation, you can edit and delete them. But if it's blank then I would say you probably won't be able to (but I'm not positive).
-tkr
Old 07-20-2001
zip's Avatar
zip zip is offline
1K Silver Member
This one I figured out after I posted...go figure. If you right click on the track in console view the select >> edit automation << you can use the eraser to wipe out the whole thing (or a selct piece).
I've got PA8 and would upgrade but I am hoping to eventually get the Digi001 / Protools set-up since I need a new soundcard anyway....I've got a 16 bit....
Thanks!
zip >>
