Pan Fade etc. Envelopes When Would I use them?
I"m primarily a hip hop producing also tryna branch out to R&B and reggae i use sonar i see people talkin about the envelopes but don't know where i should put them if i do need any can someone gimmie me an ex or something
here is some work i've done u can tell me what u think www.mp3.com/beatmakers
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage |
Envelopes are used whenever you wish to make a volume (or pan) change on just a portion of a track.
Example: You have two singers singing two-part harmony. After balancing their respective volume levels you notice that on one phrase within the song, one of the singers got louder and the balance between the singers is thrown off. You put a clip volume envelope on the loud singer, and throw a couple of db drop at the start of the phrase, and raise it back to 0db gain at the end of the phrase. Exzample 2: You have a lead guitar part (or sax, or whatever) that sits among the other instruments for most of the song - but you want to bring it forward in a couple of sections - maybe where it takes a solo. Put a volume envelope on the track and give it a few db of gain in those sections. Bottom line, envelopes are simply fader automation. They raise or lower volume settings (or change panning) at certain times within the song. The degree of change and where they occur are settings you program into the envelope. IMHO they are the only way to automate, and you should never, ever look at the stupid Console view. BTW, Sonar also has FX envelopes as one of it's neat new features. This allows you to change the amount of FX at particular spots in a song. It's the only recording software (as far as I know) that has this feature. |
You use volume or fade envelopes any time you want an instrument/vocal/sound to either change volume or pan from one speaker to the other through out the song. I listened to some of your songs and everything is "dead center", I think that some of the weird effect sounds (and even the main sounds for that matter) could be panned off center for a really cool effect. You don't have to pan much just slightly off center can really make a difference, but you just have to experiment. Try things out of the ordinary and it just may sound pretty cool and wind up in one of your songs. Especially in your type of music, you can afford to have really crazy things happening in there and all it will do is add to the song and you don't have to worry about taking the attention away from the vocals.
Hope some of that rambling helps. ![]() -tkr |
thanks alot and thanks for listening
