Old 06-14-2001
noground noground is offline
Junior Member
noground is on a distinguished road
Arrow 2-channels with sidechain
I'm looking for a 2-channel compressor/limiter/gate with a sidechain input for about $300 or less
Anyone have any suggestions? The only affordable one I've seen so far is the Behringer MDX 2200 Composer Pro.
I'm confused about something else too: what is the use of a stereo compressor? Is it just the same as two compressors with one set of controls?
To me it would seem that if you are miking and compressing 2 different sources, they should each have different compressor parameters to make each one sounds the best. Even if the two mics are very close to each other, wouldn't there be enough of a difference to merit independent controls (if even just a couple db's threshold)?
-Matt
Old 06-16-2001
Junior Member
I'm pretty sure my questions above are quite uninformed, but I've got to learn it somewhere. Can anyone help?
Old 06-24-2001
PRiZ PRiZ is offline
Expert Member
PRiZ is on a distinguished road
I'd also like to know...?
Old 06-24-2001
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
There are basicly two types of compressors when it comes to
stereo control.
The true stereo which compresses both sides of the stereo
using only one control button - Threshold etc....
The Dual monolinked compressor that has the ability to compress 2 different sides independently or linked.
In the "Link mode" some compressors then become like a true stereo compressor and have on side control both sides or on some compressors you can link them but still have seperate control.
Basicly if you will run your mix through a stereo compressor ( like many engineers do....)(or a drum group...) you want the two sides to work together or else you will have a balance problem.
However !!. I personaly question that aspect and prefer myself to compress independently both sides of a stereo mix for a simple reason.
Imagine a mix were a single Tom comming from the left side is very strong in its output... why would I want the other side to be compressed as well?. It is much more work and time but IMHO
you can get better results by compressing both sides with out a linked mode on the compressor.
Old 06-24-2001
HearClear HearClear is offline
Junior Member
HearClear is on a distinguished road
I have a composer pro and I'm very happy w/ it. It has balanced ins & outs, the side chain features (i don't use the s.c.), and has duel operation for stereo applications. I would not recommend buying a 3630.
Adam
Old 06-24-2001
Expert Member
sorry...
not getting through to me in the area of vocals...?
What is better, does it matter... a mono preamp, good or bad?
Old 06-25-2001
Shailat's Avatar
Period
Priz,
You mean mono compressor ?.
There is nothing wrong with using a mono compressor for vocals.
Old 06-25-2001
regebro's Avatar
regebro regebro is offline
Insane Genious!
regebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond repute
I'm worried that, although this is a compressor thread, nobody has mentioned the RNC yet. Are you guys feeling well?
Random Pavarotti Disease Victim.
