Old 2 Weeks Ago
Brad_g Brad_g is offline
Newbie
Brad_g is on a distinguished road
recording drums
how can you record all the drums through the mbox mini? or can you even? if not whats the next option?
Old 2 Weeks Ago
Nakatira's Avatar
Nakatira Nakatira is offline
That Norwegian Bastard
Nakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond reputeNakatira has a reputation beyond repute
If I`m not mistaken the Mbox mini only have one xlr input. and then one D.I./line in input.
So recording drums with just one mic wich this box offers, will do as a sketch I supose, but I`d go with at least 2 channels to record the drums.
You could sub mix it on an external mixer and the send it sub mixed to 2 channels on your mbox.
If you want more channels, wich the majority usually want when they record drums, buy something with more inputs.
I`m thinking your using Pro tools, hence the mbox,
perhaps mbox 2 pro would do the trick.
I`d go for something like a 8 or more channel interface
Buy My Record, or APL will think your a douche, Rami will kill you and Gerg will yell at you real hard.
http://daccord-music.com/?p=30
Old 2 Weeks Ago
Newbie
but i have to use digidesign interfaces only right? so the cheapest one with 8 inputs is the 002 or 003! or are there some other ones that will work?
thanks!
Old 2 Weeks Ago
Nakatira's Avatar
as long as you want to use, pro tools, yes.
Allthough I think M-audio makes some stuff that can be used with pro tools as well, thats cheaper, I think.
But crappier, my experience with M-audio is a lot of noise in the units
Old 2 Weeks Ago
Newbie
ok thanks!
Old 2 Weeks Ago
theEND theEND is offline
Registered User
theEND is on a distinguished road
If you're using Pro Tools to record none of the MBOX 2 family units would work as they have a max of two mic inputs and you would want to go using more than two mics. A 002 or 003 would do the trick, it has 4 mic inputs still I'd probably go for more than 4 mics for a drum set. It also depends a lot on what genre you're recording and if you want a lively sound or a more direct (For lack of a better word) and panned sound. An expansion for the 002 or 003 would be an ADAT which would give you up to an extra 8 mic inputs, it's really good for the long run but all of that is really expensive.
If it was me I'd go and buy another interface (Cheaper non digidesign, would be just as good) with more mic inputs and record the drums, on another DAW other than Pro Tools, using more mics and then take the wave files recorded in the other DAW and import them to pro tools to mix and work on them there. Its probably a lot cheaper than going ahead and buying a 002 or 003 and an ADAT for more than 4 mic inputs. It's also not a big deal since you would only use the other DAW to record and thats pretty much the same in every program.
Old 2 Weeks Ago
vijsolo vijsolo is offline
Junior Member
vijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond reputevijsolo has a reputation beyond repute
M-audio will also work
M-Audio Fast Track Ultra 8R USB 2.0 Audio Interface
This one has 8 mic inputs. It is enough to record drumzz!
The approach of theEND is also a logical one
You can get for example
Tascam US1641 USB 2.0 Audio/MIDI Interface for 300$ that includes Cubase LE 4. Actually Cubase is also very versatile DAW software and the MIDI section is much better that the one of pro tools.
Cheerz!!
www.bedroom-musician.com
Old 1 Week Ago
Fuzzhead Fuzzhead is offline
Newbie
Fuzzhead is on a distinguished road
No need to write off the interface you have just yet though. I've recorded a drumset with one SM57, and as long as you mess around with mic placement and you're in a decent room, you can make a one-mic setup work. Doing recordings with a limited amount of gear is a good learning experience, in my opinion.
If you want an interface with more inputs, I would also reccomend the Tascam US1641... there's a new model of it that's coming out soon, so I'd be willing to bet that the old model will be/already is marked down in price. But keep in mind it won't be able to work with ProTools, so you'll have to learn Cubase.
Music:
Aaron @ MySpace.com
Aaron & Masa @ MySpace.com Noise! Screaming! Japanese exchange student!
Everlasting Echoes @ MySpace.com Nifty side project! Real live drummer! Fresh lo-fi scent!
"Punk is whatever we make it to be." - D. Boon
Old 1 Week Ago
Newbie
i might be wrong but from what iv read is that M-audio will only work with Pro tools m-powered! i have LE! or can they work with LE to?
Old 1 Week Ago
Purveyor's Avatar
Purveyor Purveyor is offline
Registered User
Purveyor is on a distinguished road
Hi Brad,
PT LE will Run only on LE interfaces..
Experiment with your mic placement. You may be surprised what your room sounds like.
Good Luck,
Mario
www.upscalemusic.com
You Can Not Control The Wind but You Can Control Your Sails
Old 1 Week Ago
Newbie
thats what i thought! thanks guys!
Alt. Rock recording with female vox, hand drums, drums, acoustic + electric guitars dreamsound2 MP3 Mixing Clinic 1 12-26-2008 23:47
Tuning Drums For Recording Vs. Tuning Drums For Live Apps? Robertt8 Drums and Percussion 24 01-07-2005 16:53
Recording drums using 4 channels on a PC recording enviroment.... mastahnke Microphones 8 09-18-2002 11:31
Recording drums using 4 channels on a PC recording enviroment.... memo Drums and Percussion 0 04-17-2000 12:34
New recording studio and recording stereo drums Admiral Digital Recording & Computers 0 10-21-1999 23:48
