Noise / hum in my recordings
Hi folks, I've just bought a tascam DP02 which I've tried to use to record guitars / vocals etc then transfer onto PC to mix / master. The trouble is, when I arm the 'record' track, there is suddenly a buzz / hum present. I have tried numerous guitars (the worst sounding of them was an electro-acoustic) run both directly into the Tascam, or via a Line 6 POD. I have also tried numerous guitar leads. Still the noise is there and it ruins the recoridngs. More worrying still is the fact that I am getting very tiny but sharp electric shocks (feels liek little needles) from the hardware (bridge etc.) of the electric guitars. Also, when I touch the Tascam's chassis, the buzzing significanly reduces, as if it's using me as an earth! i have tried a different power supply (my own old & trusty) and it does reduce the noise / hum by about 50%, but it's still audible in the recordings. I have sent the Tascam back to the supplier who have tested the unit and said (after testing) that they can't find a fault with it. So, I'm stumped. Any ideas? Coudl my electric supply in the house by too, er, strong (live / not earthed propely) (I've tried the Tascam in numerous power sockets around the house and had varying results). Any ideas on how to solve thiswoudl be greatly appreciated as I'm not a technical guru and i just want to make nice quiet recordings (like I use to with my old Fostex VF160).
You're joking, right?
Send it back again. Double check the + versus - centre on your DC pin first though.
Cheers ♫ Jim |
No joke... I did send it back (they've still got it) - they called yesterday to say they have tested it and it's working fine, no problems, can't trace any fault at all. What makes me think it's our electrics is that when I plug a mic in to my other recording set up (Fostex Vf160 and / or PC based set-up), if I touch the mic with my mouth or get too near to it with my teeth, I get tiny sharp electric shocks. So it seems reasonable that this may be an issue with the earthing at my end. The Fostex VF160 uses an IEC cable (direct wall to unit, with an earth) - the Tascam DP02 uses an in-line power supply (figure 8 connector, no earth). Wonder if that's got anything to do with the hum / buzz noise showing up on the Tascam?
i've had this before and there are a couple of things you could try which solved it for me:
I'm afraid thats all i have, and thats only from past experiences and frustation! ![]() |
Yes it does, doesn't it.
Look for a ground. Make sure the sparky didn't hook it up to the new , plastic plumbing. ![]()
Cheers ♫ Jim |
thanks. I did check a few of those things, but I will certainly consider all of them next time. I think the fridge is on the same ring, so maybe that's an issue. I've just been to Maplins to buy a mains tester plug (£5.99) which I'll use to see if there's any issues with the outlets. Then I'll scratch my head again.
Agreed that it sounds like a bad building ground. Get it fixed. That's a safety problem.
| HUM and noise destroyer | walters | Recording Techniques | 11 | 08-18-2006 14:20 |
| Korg Triton Hum noise | Next Level | Keyboards and Sound Modules | 10 | 05-03-2006 12:43 |
| intermittent Hum/noise | Rob Thorworth | Studio Building & Display | 0 | 09-04-2003 14:00 |
| Noise Noise Noise!!!!!! How do I get rid of 60Hz hum? | nemal | Recording Techniques | 12 | 11-29-2000 09:44 |
| Noise in recordings is same sound as noise on phoneline | MrLip | Other Equipment and Reviews | 1 | 10-09-2000 13:38 |
