Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 3 Weeks Ago
notCardio notCardio is offline
I walk the line
notCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond reputenotCardio has a reputation beyond repute
Question Audio time stretching
Does Reaper do it? Can you use it to load in audio and slow down it down while maintaining pitch to learn solos?
"One thing led to another and, before we knew it, we were dead." --Michael O'Donoghue
Old 3 Weeks Ago
d.bop d.bop is offline
Senior Member
d.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond repute
It sure does.
You can use the playrate slider at the bottom to speed up or slow down playback (right-click to preserve pitch)
You can also time stretch recorded/imported items by holding alt and dragging either edge of the clip.
Alt + Enter will bring up the project settings where you can specify the project's default pitch/time stretching algorithm. F2 will allow you to do it per-item.
Old 3 Weeks Ago
I walk the line
Thanks!
Can you slow it down a lot, or just a little?
I don't have Reaper, but if it does what I'm looking for easily, then I'll get it.
Old 3 Weeks Ago
Senior Member
I'm not at home right now but I think the max speed is 4x and min speed is .25. There is a playrate slider next to the transport that allows you to adjust it to whatever speed you want.
You can also right-click the playrate slider and change the minimum and maximum speeds if you would like.
I suggest you just download it and try it. The installer is only 4mb and it has an uncrippled 30-day trial.
Old 3 Weeks Ago
I walk the line
Cool.
Thanks.
Old 3 Weeks Ago
Senior Member
No problem. I hope it works out for you
Question On Time Stretching? X_Discord_X Cool Edit Pro / Adobe Audition Forum 2 08-14-2009 12:10
Time-stretching in Cool Edit 2.0????????????????? batchmister1 Cool Edit Pro / Adobe Audition Forum 0 02-09-2008 12:24
Time Stretching Gear intelkt Newbies 1 01-18-2005 11:54
Time Stretching In Sonar BluesMeister Cakewalk / Sonar Forum 1 07-18-2003 02:25
Real time audio stretching effects? Uladine Digital Recording & Computers 0 06-22-2002 07:35
