panning the track's send
so lets say i have a 24 track session and i add track #25 as a reverb channel and send 3 out of my 24 track to the reverb (#25).
on one of the 3 tracks i want to send that reverb 10% to the left. I cant pan the reverb channel (#25) to the left cause that will affect the other 2 channels reverb. I tried opening the send on the track and pan that way, but it wont change left or right. is there a way to do this without opening another track & plugin? thanks my fellow Reaper users.... ![]() -mike-
www.MikeUlloa.com |
The easiest way that comes to the top of my head is to create another reverb channel, i.e. track 26, load the reverb FX into it, pan it a bit left, and send the track in question to this channel.
I have a theory about that |
This will work if you pan the send on the track, the problem is with your reverb plug in, I personally use cakewalk sonar and the lexicon reverb will not work either, I use the perfect space convulsion reverb and it works, it has to do with stereo and mono reverbs, you need the correct reverb plugin....
thanks
thanks to you aswell gecko zzed if i cant find the right plug, thats what i will have to do. -mike-
www.MikeUlloa.com |
You can pan the recieves too
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
| Anyone ever send a track to a tape recorder then back? | DAS19 | Recording Techniques | 41 | 10-22-2007 13:16 |
| Track Panning | jonmorri | Mixing / Mastering | 9 | 07-10-2007 16:41 |
| send reverb to aux or directly on track? | djclueveli | Mixing / Mastering | 2 | 12-11-2006 11:30 |
| Sonar 4 - send each track to mixer.. | drpfeffer | Cakewalk / Sonar Forum | 4 | 06-14-2005 06:47 |
| Is there a way to send each signal from a mixer to a seperate track instead all in 1 | word_play | Cool Edit Pro / Adobe Audition Forum | 5 | 08-05-2003 05:13 |
