10-04-2009
Senior Member
REAPER v3.12 - REX and CD burning for all platforms, lots of other goodies
Originally Posted by reaper.fm
+ Automation lanes: fixed possible crash when removing FX parameter envelopes
+ CD burning: fixes to native XP mode track divisions
+ Extensions API: GetSetMediaItemInfo() fixes for fade shape settings
+ Fade drawing: when using full-area filling, fixed drawing when zoomed in
+ FX: per-FX buggy plugin compatibility mode (assumes plugin is not threadsafe, needs constant precleaned buffers, etc)
+ Hardware outputs: post-fader track outputs obey track polarity control
+ MIDI editor: show notes pressed as long as the input note is pressed
+ OSX: improved drag/drop support
+ OSX: support for control+alt+drag to render to new file (drag to desktop, finder, sampler, etc)
+ OSX: CD burning support
+ OSX: REX support
+ OSX: special casing for POD Farm VST misreporting view type (VST 2.4 should be composited view)
+ OSX: fix for some AUs that do not export automatable parameters until after audio streams are initialized
+ OSX: added correct file locking to prevent writing files open for read
+ Pencil mode: fixed fade/autofade settings for newly drawn media items
+ ReaControlMIDI: support for raw mode (0-127 access to all CC messages)
+ ReaControlMIDI: envelopes and TCP knobs report the same value as the slider (0-127, 0-16383, or on/off)
+ ReaControlMIDI: support for storing/sending sysex dumps up to 64KB
+ ReaScript: run Python or Perl scripts that call Reaper API functions
+ ReaScript: assign reascripts to key commands or toolbar buttons
+ VST bridging: optimized plug-ins that call for tempo information
+ VST bridging/firewalling: per plug-in option to embed UI (not as compatible, less crash-resilient)
+ VST: safer querying of text strings from certain plug-ins
+ Win32: async file reading now has more grace on error
+ Win32: file locking improvements (no longer allow writing to media files that are open and online in REAPER, etc)
+ x64: VST bridging performance improvements, ReaRoute performance improvements
+ x64: will now use same config path as x86 (unless appdata/REAPER64 is valid)
+ x64: REX support (via bridging)
+ x64: fix for certain (broken) ASIO drivers
http://www.reaper.fm
