Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 09-30-2009
musiq_lova musiq_lova is offline
Registered User
musiq_lova is on a distinguished road
Adjusting waveforms so they do NOT pass the white horizontal lines?
Hi everyone,
Ok I need a little help with Audition 3. I have a WAV file (same song) but from 2 different sources... One is obviously not touched at all, but the other is edited (sorry i don't know what effect is used) so that it does not pass the horizontal white lines on the tops and bottoms of the waveform in Edit View.
Here are images of what I mean, I'd like to know what do I need to do to get the effect of the waveform that doesn't pass the white lines?
PASSES LINES:
DOESN'T PASS LINES (the effect I want)
How do I do this?
Old 09-30-2009
RawDepth's Avatar
RawDepth RawDepth is offline
1K Silver Member
RawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond repute
One quick way to achieve that is with hard limiting.
Click on EFFECTS > AMPLITUDE > HARD LIMITING then set the amplitude limit to be at -1. (That is, I am guessing your white line is set at -1 dB.)
___________________________
________________________________________
Old 09-30-2009
Registered User
Thank you for your quick response.
I got the -1db part that makes perfect sense and worked. My next question is, by looking and comparing the two different waveforms I posted is there a way to tell what values to use for "Boost Input By", "Lookahead Time", and "Release Time"?
Old 10-01-2009
RawDepth's Avatar
1K Silver Member
Originally Posted by musiq_lova View Post
...is there a way to tell what values to use for "Boost Input By", "Lookahead Time", and "Release Time"?
I would use the following.
Boost = 0 (This feature will raise the overall volume prior to limiting the peaks)(rarely needed)
Lookahead = 7 (This aides in pre-calculating where each peak begins and ends)(a delicate balance between necessity and redundancy)
Release = 100 (This forces limiting recovery after peaks go below threshold)(based on the size of the transient peaks)
There is more to those descriptions but I really tried to simplify this answer assuming that you are a beginner.
Hope this helps.
Horizontal, Vertical, thicker? RAMI Studio Building & Display 20 04-13-2007 13:33
Using a high pass or low pass filter rgraves Cubase User Forum 7 11-22-2006 07:57
Vertical or Horizontal TonyK Studio Building & Display 7 08-22-2003 09:19
Horizontal monitor angel? ola Studio Building & Display 1 10-08-2002 15:09
Why are slat resonators usually horizontal? Todzilla Studio Building & Display 3 05-29-2002 16:45
