Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 09-20-2009
d.bop d.bop is offline
Senior Member
d.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond repute
REAPER v3.11 - Automation drawing, plug-in firewalling, lots of other goodness
Originally Posted by reaper.fm
* Automation: freehand envelope drawing (ctrl+drag by default, optionally ctrl+alt+drag)
* Multiproject: support for playing background projects with current, option to sync start times
* Take: realtime reverse take
* Toolbar: arm a custom toolbar button by right-clicking, click an item in the arrange view to run it
* VST: configurable bridging/firewalling on x64 and x86 (prefs/VST, per VST option in FX browser)
* Action: crossfade any overlapping selected items
* Action: toggle master track and tempo envelope visibility together
* Action window: allow removal of multiple key bindings at once
* ASIO: fixed compatibility with Zoom R16 (and possibly other devices)
* Automation: envelope data reduction during recording is now on by default
* Automation: add a point anywhere in an envelope lane by clicking
* Automation: envelope lanes now respect locking
* CD burning: better gapless CD image generation, more accurate marker/region track generation
* CD burning: allow recording multiple copies from single render, better error messages
* Cleaner display of track information on routing/fx/envelope windows/tooltips/etc
* Editing: fixed shift+click for multiple selection in arrange view
* Editing: do not allow track envelopes to move vertically when ripple edit is enabled
* Fades: option to disable autofades/autocrossfades for MIDI items
* FX autobuild routing: clearer indication that cancelling autobuild will still load the FX
* FX chains: loading FX chains will search the path of the .rfxchain for media files (for reasamplomatic/reaverb)
* FX window: UTF-8 support for preset/program combo boxes
* Help: useful information (info or context sensitive help) displayed below TCP section
* JS: fixed a bug causing potential crashes when parameters automated
* JS: new slider() function to get a slider by index (values 1..64)
* License keys: updated text for non-commercial to be more accurate (personal/small business)
* Loop recording: fixes for rounding errors causing items to be slightly too long
* MCU: better support for emulated surfaces that do not notify touch state
* Media explorer: menu options to enable RPP preview, disable tempo sync
* MIDI editor: velocity lane editing affects only selected notes if there is a selection visible
* MIDI editor: show MIDI track input on piano keys
* MIDI editor: less eager to show empty space to the left of the MIDI item
* MIDI editor: fixed drawing controller data over existing data on another channel
* MIDI editor: actions to move to previous/next lyric
* MIDI editor: fixed blinking cursor reappearing when offscreen
* MIDI: in-project MIDI preview should now interrupt audio less
* Mixer: improved extended mixer FX context menu layout
* OSX: fixed low latency MIDI output mode
* OSX: fixed menu key binding labels
* OSX: fixed MIDI note name editing
* OSX: AU compatibility improvements
* OSX: fixed key assigning special keys in actions window
* OSX: fixed keyboard navigation in file open/save dialogs
* OSX: holding shift during startup now prevents REAPER from loading last project (like on Win32)
* OSX: fixed routing dialog scroll issues on 10.4
* Pan: allow settings as low as +1/-1% with control+drag
* Peak building now handles multiple projects nicely
* Pencil mode: obey loop preference when drawing empty MIDI item
* Project settings: project media browse dialog better deals with relative paths
* ReaSamplomatic5000: ability to fully buffer smaller audio samples (better performance)
* ReaSamplomatic5000: removed pan automation zipper noises
* ReaSamplomatic5000: volume/rate/etc automation now affects playing samples
* ReaSamplomatic5000: parameter for MIDI pitch bend amount (default is 2 semitones, can do up to 12)
* ReaSamplomatic5000: safer thread-source management
* ReaSamplomatic5000: notify undo state when sample changed
* ReaVerb: less RAM use during file loading
* Safer memory management in undo, ReaVerb, and other areas
* Snap: relative snap support
* Snap: when grid-snap settings follow visible grid, do not snap if grid is not visible
* Selection: faster selection of multiple tracks in some cases where other windows are open
* Take: fixes/improvements to loop section
* TCP: Fixed track VU meter glitch
* TCP/mixer: mousewheel support on FX knobs and sends
* Tempo markers: manual edit of position defaults to timeline units (bars.beats, min:sec, etc)
* Undo: fixed multiproject undo system bugs
* Undo window: safer destroy on exit
* User preference: default track height in new projects, set to medium (was small) by default
* Virtual MIDI keyboard: arrow keys can be passed through to main window
* VST: per instance option to disable PDC
* VST: safer preset changes with some buggy plugins
* Windows Vista/7: validate ini file path before using (to ensure that it is writeable)
* Windows: fixed some issues with long strings in text boxes
http://www.reaper.fm/
Hooray!
Oranizing Plug-ins in Reaper mattkw80 Don't Fear The Reaper 4 01-07-2008 23:53
Sonar 6 and Reaper automation... urobolus.com Digital Recording & Computers 2 03-28-2007 21:06
Reaper FX Automation danny.guitar Digital Recording & Computers 4 03-28-2007 01:45
advance automation with plug ins walters Recording Techniques 4 05-21-2005 05:36
MAC software / lots of plug-ins shortyc Free Ads for Music / Recording Equipment 0 06-25-2002 09:20
