Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 09-17-2009
alfordtp alfordtp is offline
Registered User
alfordtp is on a distinguished road
as always, latency...
Like most people, I find that latency is a neverending battle.
Here is my setup: I am running vocals and guitar (sometimes together, sometimes independent) through a mixing board. Then out of the mixing board into guitarport. Then guitarport through usb into the computer. I do it this way because my line-in is giving me too much extra noise. Using ASIO4ALL, I can get the guitarport to come through pretty well into the computer. I have 2.5GB of Ram with a Pentium 3.0GHz processor.
I can get a single track recorded, but when I go to lay down another track, I get latency problems while trying to monitor the first track.
Which settings do I mess with first to help with this issue? Is there any way to route the inputs and outputs to get around this? Any help would be nice to this newbie.
Old 2 Weeks Ago
Lo-Fi Mike's Avatar
Lo-Fi Mike Lo-Fi Mike is offline
Dedicated Member
Lo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond repute
are you monitoring your input from your interface or Reaper?
Edit:
do you mean when you play the first track back thru your monitors the play line is not lined up with the perspective audio you are hearing?
i wanna help, but i'm not totally sure what is going on...you computer seams to be fine..and you should be able to monitor thru your usb interface latency free. ...what is your buffer set at (ie. 256, 512 )
www.MikeUlloa.com
Last edited by Lo-Fi Mike; 2 Weeks Ago at 10:20.. Reason: trying to understand the question
Interface Latency vs. Output Monitoring Latency LevelSongD Digital Recording & Computers 2 09-11-2009 08:46
latency?? multitrak_ent The Rack 3 11-19-2004 14:48
What is good latency vs. bad latency? Newbie-Doo Newbies 2 09-28-2004 11:13
latency xparkerx Digital Recording & Computers 3 04-23-2004 13:39
Latency Bert0529 Newbies 1 03-19-2004 20:20
