Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 08-16-2009
FunkDaddy's Avatar
FunkDaddy FunkDaddy is offline
Senior Member
FunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond repute
MIDI Editing Question
Not sure how to phrase this, hopefully my explanation works...
When I'm editing MIDI, usually SD2.0 grooves, sometimes I want to add another measure or section in between two existing sections. Right now I have to manually ctrl-click everything before or after the area I want to add to, to move it all around as one group or else I get gaps/overlaps when I add stuff.
Is there anyway to set an option to make the midi grooves "stiff"? Lol I have no idea what it would be called, but basically, if I move one section of midi that is touching another section, they would just move as one group...the one I have selected "pushing" the others instead of integrating/overlapping with them?
Ctrl-clicking isn't the most time consuming thing but it is a bit annoying.
Old 08-21-2009
DarkFriend's Avatar
DarkFriend DarkFriend is offline
Senior Member
DarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond reputeDarkFriend has a reputation beyond repute
You don't have to control and click for each midi segment. Use the mouse to click and drag to "lasso" all the pieces and move them left or right to create open space. I don't think there's any way to "insert" a midi segment and automatically bump the other midi segments.
Old 08-21-2009
d.bop d.bop is offline
Senior Member
d.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond reputed.bop has a reputation beyond repute
To clear up that last post, lasso is right-click + drag.
You could try turning on "Ripple Editing" just for the track (click the ripple edit button once for selected track, twice for all tracks)
...I just tried it for you
Ripple editing only seems to push other items forward when you click "insert -> new midi item."
An alternative is to select all items on the track then right-click -> "glue selected items"
All of the midi items now become one larger item that you can move around. Then to edit things in, just press "S" to split the item where you want to record and move the new selected item out of the way. Now record in your empty space
I hope that helps somewhat.
Midi editing and controller lane question... xstatic Cubase User Forum 7 11-23-2007 05:31
Simple MIDI editing question guttapercha Cubase User Forum 12 11-02-2006 16:26
Midi editing TelePaul Cubase User Forum 4 07-14-2006 15:21
Editing - Computer Editing - Editing Software-Features, cost, comapat, etc. junplugged Recording Techniques 4 04-25-2005 11:12
About MIDI Music Editing ChrisEllington Cakewalk / Sonar Forum 2 10-03-2001 01:25
